It is currently Sat Jun 13, 2026 1:38 pm
 Post subject: block strengthening?
PostPosted: Wed Jul 20, 2011 8:19 pm
What kinds of things are you boys doing to the blocks to strengthen them up for turbocharging? o ringing? custom stiffener plates? four bolt mains? I have no idea if any of these things are even possible on this block.
1969 Dart Custom (great grandmother bought new in '68 )
1990 Daytona running 20psi
2007.5 CTD 3500 Megacab
PostPosted: Wed Jul 20, 2011 10:18 pm
Car Model: 64 Valiant
Main straps and girdles are done on other inline engines like the Chevy 250/292 and Ford 240/300 engines. So it can also be done on the slants if you feel it needs them. Since they only have 4 mains it might be a good idea if your planning a really high boosted combo. O-ringing the block would be a plus also.
PostPosted: Wed Jul 20, 2011 11:55 pm
Does anyone have cad-file for maingirdle?
PostPosted: Thu Jul 21, 2011 1:06 am
Fix the stuff the breaks first. You'll lift the head off the block before the bottom end blows out. It's been proven you can run 12s in a full weight street car without touching the long block except to o-ring the deck and screw in head studs.
PostPosted: Thu Jul 21, 2011 6:21 am
Yeah, it really depends on how much power you want to make. Tilley has not used main girdles and has made 630 HP. He has broken some NA motor blocks though due to high revs and/or detonation, as have others with nitrous.
PostPosted: Thu Jul 21, 2011 3:10 pm
So I bought a built moter, 225 bored .040 and it has a radiused and carbon nitrided crank (listed as TUFFTRIDED), what should I stop at with shot peened stock rods as opposed to going further with an aftermarket steel and is aluminum just as strong but stresses quicker?
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Thu Jul 21, 2011 3:18 pm
Just depends on what your end goal is with your engine. I would stick with a good forged or billet steel rod. Aluminum rods, while they do have their place in a performance engine, they also have a life expectancy that unfortunately seems to end at the wrong time, while steel rods can last indefinately when engineered for the correct applications.
PostPosted: Thu Jul 21, 2011 3:21 pm
As soon as I get a block lined up I can generate one or even make some.....if there is any interest in it.
PostPosted: Thu Jul 21, 2011 5:58 pm
i cant really say what horsepower goal i will be aiming for as i don't plan on doing this project for a few year. i would love it to equal to a mildly modded small block. so in the range of 300-400 hp. i have only been part time researching information right now, but believe i would like like to go a EFI and turbocharged.
please excuse me if this topic is asked too much. i haven't spent too much researching this as of late.
PostPosted: Fri Jul 22, 2011 9:14 am
I fill my blocks with block fill up to the freeze plugs to stiffen the blocks,Guzzi Mark
PostPosted: Fri Jul 22, 2011 1:22 pm
I put about an inch of fill in the bottom of mine. No cooling issues as I drive it on the street as well.
11.02 @ 120.56
Chassis dyno
PostPosted: Sun Jul 24, 2011 4:11 am
400 HP will live just fine with no block strengthening. I am also targeting 350-400 HP in my '68 Dart and plan to do that with a stock rebuild 150k mile motor (cast pistons, stock rods...). It makes just under 300 HP now.
Folks have made over 600 HP with no girdle or explicit block mods such as that.
PostPosted: Sun Jul 24, 2011 8:08 am
What are you trying to do? Stock rods that have been de-burred and resized will hold up to a lot of abuse.
I have a set of 198 rods in my junk that have held up to being spun over 6000 for a long time.
PostPosted: Tue Jul 26, 2011 2:26 pm
Thank you, I,ll get em shot peened then.
PostPosted: Wed Jul 27, 2011 9:29 pm
shaker223 you told me about block fill about 2 years ago in private messages when i quizzed you up about turboing my slant. What is the product name?
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 1 guest
