It is currently Fri Jun 19, 2026 10:11 pm
 Post subject: 727 shift points
PostPosted: Mon Jun 27, 2011 8:16 pm
howdy folks, i have a 727 sitting behind my trusty slant in my 66 a100 and the shift from 1st to 2nd seems a bit hard... it really winds out in first before shifting... drops into 3rd nicely though... is this just a kick down linkage adjustment or do i need to drop the pan and give her a tweak?
PostPosted: Tue Jul 19, 2011 4:05 pm
I would go after a sticky 1,2 shift valve, the goveror pressure overrides the kickdown at a certain speed (other end of valve). If th 2,3 shift will do all you ask and first and second gear are good physicaly, a delay might be that it sticks untill the govenor pressure is high enough.
I would take the valve body down and inspect the 1,2 shift curcuit, (two valves and a ball or something).
The obstuction could fall away with fluid when you remove the valve body so if you don't find something its o.k., you might look for a little speck of dark like sand or gasket or you might look for a little glob of cloth saturated with tranny fluid. Pull some fuzz of a shoelace and mix it with tranny fluid if you want an idea.
Even transmission shops won't clean a valve body on a rebuild unless that was diagnoised so trust me you don't want to add to you problems.
Advise should be taken as ongoing, that way, when you get to realizing what you are doing you can include yourself.
PostPosted: Wed Jul 20, 2011 3:22 pm
Should be cut and dry operation with a service manual to find the shift valve, and pay attention to the torque of the valve body bolts, you can warp the valve body with pressure from a screw driver and you hand.
PostPosted: Fri Jul 22, 2011 9:41 pm
thanks fellas... i have a service manual i'll take a peek...
PostPosted: Fri Jul 22, 2011 10:25 pm
6 Pack Dart
Check to see the kickdown linkage is set correctly first. Might be it is set to long.
Richard
