It is currently Wed Jun 17, 2026 10:45 am
 Post subject: 727 for my slant six
PostPosted: Mon Aug 01, 2011 6:55 pm
i want a performance 727 for my soup'd 225 where should i look i am replacing my old push button
PostPosted: Mon Aug 01, 2011 6:58 pm
This is not a smart idea. You'd have to make a bunch of costly, difficult mods to fit a 727 in your car, and you'd wind up with an unnecessarily heavy, unnecessarily power-hungry transmission. You don't need a 727; a 904 in stock form is plenty robust for even a stout slant-6, and the 904 can be built up to take whatever most any slant-6 (or even a pretty strong V8) can dish out.
PostPosted: Mon Aug 01, 2011 7:11 pm
I am bored out over .060 my head is milled .125 is port match for my intake enlarge bowls & valves 1.6 rockers high lift springs true dual exuast 4 barrel 525 road demon junior And a cam .619 lift running dur of 274 advanced dur 320 power range between 4500 7k rpm 2300 stall tired of breaking 904s i have twisted the input shaft off two and other problems in my lil dart your fast on the response
PostPosted: Mon Aug 01, 2011 9:59 pm
If you are (were) running '67 & earlier "small" converter then I'm not surprised that you broke the input shafts. Later 904s lived behind 340s & 360s, so if you get the right parts (HD/ racing) then you''l be fine. (hell, some guys run 904s behind BB... & have them live! The only question is what year crank is in your engine? I don't know if there is any way to fit a later (68-up) "large" converter & input shaft into a 67-down crank.
63 Valiant Wagon
225 - 4 bbl
PostPosted: Tue Aug 02, 2011 8:13 am
Sure there is: enlarge the crank counterbore! :shock:
If we're going to later whole transmission, though, we're losing pushbutton shift.
PostPosted: Tue Aug 02, 2011 8:48 am
i have already pulled out the push button shift and add an additional cross member for the late model 904 to answer dan and what is it about the small converters i am still using that twists my input shafts in two or rips the front pump seals out that the later larger ones would be better. And my block is a 68 with the orginal 63 crank and rods in it Ooo and i have been using a reverse manual valve body with a B&M Z Gate shifter
