It is currently Fri Jun 19, 2026 10:31 am
PostPosted: Sun Jul 31, 2011 7:00 pm
while studying the flow issues on our Hooker Comp headers I found statements about an over laping cam can help with intake gas flow into the cylinder.I am wondering who runs one on the street, also any other info..compression/valve size/carb size or ?
I am not concerned about fuel economy on our 1968 Dodge Dart
any info would be good.
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Jul 31, 2011 7:52 pm
Site Admin
I take it you are talking about high overlap event timing. Even the most mild stock cams have some overlap. Effective scavenging doesn't work without it.
For stop and go traffic, or other urban use, using a cam with large amounts of overlap will be hard on economy.
Assuming an appropriate final gear ratio, economy out on the highway can be pretty reasonable, if not better. It's all about efficiency. If the torque is high at cruise, that's good. If cruise speed is under or over where torque is fairly high, or running at excessive engine speeds, then efficiency will suffer.
Other considerations would be converter stall, and weight. If you normally drive around with 600# of tools in the trunk, a big cam isn't going to be the best choice.
High overlap cams generally have pretty high lift, and may require higher valve spring rates. That results in higher loading of the valve train. This will result in shorter service life.
2¢
CJ
PostPosted: Tue Aug 02, 2011 10:31 pm
i do... 70* Erson .475 valve lift, 246 @ .050 duration, 106 LSA
now what issue of ""flow"" are you talking about with the hookers?
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Wed Aug 03, 2011 5:41 am
they flow a lot, collector/cam overlap/exhaust tubing dia/length/muffler all add to the optium use.
slant six's RULE!
PostPosted: Wed Aug 03, 2011 9:59 am
well thats not an issue... lol... just need to have a motor that flows enough and a cam profile to take advantage of the tuned headers...
and really from the collector back it dosn't matter... as long as its not restrictive and the correct diameter it will be fine...
now when you race, make a piece of tubing with just a flange so you can adjust your collector length for max power...
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 1 guest
