It is currently Mon May 18, 2026 6:20 pm
PostPosted: Thu Aug 04, 2011 11:41 pm
Ok. So I bought the 69 dart and the engine wiring harness is trashed. Someone tried to swap in electronic ignition and failed. I am trying to decide if I should try and fix it using wire I have on hand or bite the bullet and go with the evans wiring engine harness. Anyone have any experiance with evans? Its 95 with points,and 105 with electronic ignition. I plan on running the GM HEI over the stock stuff that is sitting in there now,so if I go that route should I just buy the points harness?
Thanks!
PostPosted: Sat Aug 06, 2011 8:12 am
Anybody? Ok, does anyone know if I can use a harness out of another year a body? Thanks
PostPosted: Sat Aug 06, 2011 8:24 am
Definitely go with Evans. Very nice workmanship and reasonable pricing.
PostPosted: Sat Aug 06, 2011 8:32 am
For that price, I would get a new one.
I would get a points one for hei...
I have no idea what I am talking about.
PostPosted: Sat Aug 06, 2011 2:13 pm
Thank you guys.
Dan: you have used one of evans wiring systems before? I definitely trust your opinion,you know your electrical :D
PostPosted: Sat Aug 06, 2011 2:30 pm
Also,does anyone know if a 70 dart uses the same harness as a 69,besides that it uses a plug for the electronic voltage regulator?
