It is currently Thu May 14, 2026 11:12 pm
 Post subject: what gaskets are these
PostPosted: Thu Aug 11, 2011 6:48 pm
help would very much be appreciated :-) these are out of my felpro kit
PostPosted: Thu Aug 11, 2011 7:24 pm
1 and 2: probably oil pump cover O-rings
3 and 4 and 8: air cleaner to carburetor
5: EGR valve to intake manifold
6: ?
7: Air injection tube to cylinder head
9: Probably oil pump pressure regulator valve cap
10: There are two different distributor O-rings, are you sure this isn't one of them?
PostPosted: Thu Aug 11, 2011 7:28 pm
i suppose it could be the shaft o ring, didnt think about that. i dont think ill be using EGR, or air injection, there is a oil pressure regulator valve in the oil pump? my old worn out stock one has a sending unit, while my new one has a plug, i suppose i need to swich that out, is that what you talking about?
thanks bud
PostPosted: Fri Aug 12, 2011 6:35 am
Yes Bud you shouldn't need the oil pump one as your new pump has a new ring in it.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
