It is currently Thu Nov 26, 2026 1:03 am
 Post subject: convertors
PostPosted: Fri Aug 12, 2011 5:43 pm
In a previous insert i was told that i am twisting input shafts on the 904s in two because i am running the older smaller torque convertor.
Why is this, what is the science or mechanics behind it??
PostPosted: Fri Aug 12, 2011 6:01 pm
I think whoever told you that is full of it. I've never seen a twisted input shaft. However, a common failure w/ higher HP engines is that the pump drive hub on the converter can split or break off. That might be what they meant?
PostPosted: Fri Aug 12, 2011 6:02 pm
The 60-67 904 (small hub) uses a smaller, 3/4 diameter input shaft w/ course splines.
The 68 & later 904/998/999 (big hub) transmissions use a 7/8 diameter shaft w/ fine splines.
You must have a pretty powerful SL6 to be breaking the input shaft off the trans.
PostPosted: Fri Aug 12, 2011 6:07 pm
ya about 300 horse maybe if i am lucky quarters in the 11's when i get lucky usually 12-13's but i twist my input shafts in two or i will blow or suck the the front pump seals out in the tranny
PostPosted: Fri Aug 12, 2011 7:40 pm
Sounds to me like you need to have someone build your trans that knows what he is doing. Broken input is a sign of internal issues, not horsepower.
Do you have tire screeching, neck snapping shifts? :shock:
PostPosted: Sat Aug 13, 2011 7:12 am
Where are you located? It might be nice for some of us to meet you and see your fast Slant 6. Or, you could come to a Slant 6 drag race?
