It is currently Sat May 16, 2026 11:36 am
PostPosted: Sat Aug 13, 2011 7:21 pm
I got a 1920 from Seth, rebuilt it and adjusted to specs. New carb mount gasket as well. Got a new starter today so I could take it for a test drive. It still has the idle that you can tell is a vac leak. I sprayed starting fluid on intake to head, leak at cylinder #4. I don't have the money atm to get the gasket since it just went to a starter. So I put some jb stik on it. Was a lttle better. And yes I know before you scold me that jb stik is not the best solution but its the only thing I had. I will post a video at curb idle when I get on my computer. Also the other day it backfired at highway speed (65mph, 2800 rpm). What would cause that?
Also any suggestions on a temp fix for the intake gasket or a good gasket set to buy would be helpful.
Thanks
Cody
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Sat Aug 13, 2011 8:33 pm
here is a crappy cellphone vid.
http://www.youtube.com/watch?v=WBB7MiD_usU
