It is currently Sat Aug 15, 2026 12:10 am
 Post subject: 318 Tbi
PostPosted: Sat Aug 13, 2011 4:00 pm
hey guys, I just picked up a '90 model ramcharger with a blown engine for a $100 bucks. It has the Holly 2 barrel TBI on it. Would this work on a slant with MS running it, maybe even with a turbo?
To each his own (so what if I wanna build a 450 horse MPFI turbo /6 instead of using a V-8!)
PostPosted: Sat Aug 13, 2011 6:25 pm
I think it would work real fine, say with a supersix manifold. You could turbo that with low boost before you ran out of injector flow. Plan to make the same hp as a 318 before having to increase injector size.
PostPosted: Sat Aug 13, 2011 9:44 pm
The '88-'91 TBI system used on 3.9, 5.2, and 5.9 engines in trucks and vans is poor hardware driven poorly by poor firmware/software. You can get around the latter with MegaSquirt or whatever other control setup you want, but the hardware itself is clumsy and primitive and marginal through and through. You can surely make it work, but I think it will be more difficult to make it work well.
I could be wrong. Try it out and let us know!
PostPosted: Mon Aug 15, 2011 8:05 am
cool, I'll pull it off and put it in the shelf, thanks guys!
PostPosted: Mon Aug 15, 2011 10:57 am
Holley later repackaged the same TBI unit (only not machined for an IAC valve) with a more primitive computer as the Pro-Jection.
I've done a bit of testing with one of the Pro-Jection variants and a GM TBI on a small block Chevy (went straight to multiport on my slant six). The fuel distribution wasn't too good with either one, although they had somewhat better cold start and warm up characteristics over a carb.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Aug 15, 2011 12:05 pm
No IAC valve on the Dodge version. It used a slow, noisy, clumsy external ISC pushing on the throttle lever instead.
PostPosted: Mon Aug 15, 2011 8:29 pm
I did build an EFI system using a '90 Dodge TBI and controlled by Megasquirt. I didn't have any beef with the hardware, although I wasn't using an IAC valve. It had great throttle response, vastly improved low end torque, and never gave me a moment's trouble.
With the TBI you get the fuel pressure regulator, injectors, throttle position sensor, throttle body, and some vacuum ports all in one package. My system was on a 360 V-8. Using TBI on the long slant manifold is another discussion, but that's not an inherent fault of the hardware.
Here's a look at that TBI/MS combo in action. A few days after I got it running and tuned, I drove it to Moab (about 600 miles one way) wheeled it, and drove it home. No problems. It liked the angles much better than a carb.
Fins 'n Things trail. Obstacles are steeper than they appear.
Oil pressure was going away here. Look closely at the tire tracks...
Throttle response helps here.
And here:
When dirt biker stop to watch, you got something happening.
The system being built and tested. This was my first Megasquirt build so I was all excited. Lou made me do it.
Comparison photo of the 360 TBI venturi size (L) compared to a Holley 2V carburetor for a 360. (R) This tells you something about EFI.
Mounted on the truck with a lot of wiring to do.
Here's my thread on RamchargerCentral documenting this build. I also did the TBI on the Offy manifold for the /6 which you can read about in this section.
RIP Ramus, you were a good truck. Lost in the great shop fire of 2009.
PostPosted: Tue Aug 16, 2011 5:46 am
Great project and cool pics! Some seriously fun drivin'. Get that monkayyyy!
 Post subject: Tbi
PostPosted: Tue Aug 16, 2011 11:47 pm
Very cool, I am taking the TBI unit off of a 1992 Dodge truck, rebuilding it and cleaning and flowing the injectors, then dropping the unit on a late 70's 360 and installing it in a 62 Dodge truck.
I have also considered installing the 3.9 TBI unit on a slant six, as an alternative to a carburetor.
Fast is fine but accuracy is final. You have to learn to take your time ... in a hurry
- Wyatt Earp
Users browsing this forum: No registered users and 21 guests
