It is currently Tue Oct 13, 2026 11:56 pm
 Post subject: Clark Cortez drive train
PostPosted: Sat Aug 20, 2011 5:22 pm
My cousin told me about a Clark Cortez that might be available real cheap.I was thinking about looking at it for the engine, but Other than the crankshaft being good for a build, the rest is not ment for a performance oriantated build, right? or am I wrong? I am interested in looking at the 4 speed also. My cousin used to own this thing, and told me it was way cool, back in the late 80's and into the 90's.....but I dont know what is left of it now.
Wife's: 64 Valiant
PostPosted: Sat Aug 20, 2011 6:54 pm
Andrew
If its in any kind of decent shape I would keep it as a MH. They are getting rare and parts are in demand. If I found one close to me I would use it. I really is just a run of the mill slant as far as the actual slant goes.
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Sat Aug 20, 2011 9:40 pm
Car Model: 62 Lancer, 63 D100
Andrew, We owned a 1967 Clark Cortez for 12 years. Sold it 2 years ago. The engines, if original, were industrial models with good cranks and heads. Trans is from a Clark forklift, 4 speed granny gear 1st, and front wheel drive. They handle great because of very low center of gravity, but very underpowered. You will creep in 2nd gear up a 4% grade. Body is all steel and they rust from the inside-out. We had great times in ours but the Half Moon Bay salt air got to it. Sold it for $1000 with 5 nearly new load range E radials. It had 68,000 original miles.
61, 62, 63, 64 Valiants
62 Lancer
64 Darts
66 Barracuda
64 D100
77 Aspen
PostPosted: Sat Aug 20, 2011 10:21 pm
Didn't know what it was so I googled it. Wow, now I want one of those. I'll be needing a mid sized camper in a few years.
ski
PostPosted: Sun Aug 21, 2011 8:02 am
Me too! A little EFI and turbo will fix that power...
It's a Slant thing. Even I don't understand.
1974 Duster, EFI /6 soon to be turbo...
Get that Monkay! Get that nasty thing!!
PostPosted: Sun Aug 21, 2011 10:56 am
Poser
Hey Kidd, if you end up with this thing and dont want the intake/carb I would be interested. The set up while not the most performance oriented is still kinda cool once you consider the weirdness factor. Anyway, good luck with this. Hell, ya never know a retro motor home all fixed up would be way cool as well. All the best, Wayne.
PostPosted: Mon Aug 22, 2011 10:03 am
I'm with you wvenable, I am definitely interested in that intake/carb too. I've got some ideas for one and need an example to work with.
~RDE~
PostPosted: Mon Aug 22, 2011 5:09 pm
"Jim Krantz purchased the tooling, spare parts, and a few unfinished units around 1980 and moved operations to Lafayette, La. There, under the name Cortez Inc., he sold parts, serviced coaches, and performed drivetrain conversions on Clark models using the Kent drivetrain. One unit was produced in 1989 and is still in use. Operations ceased in Lafayette around 1990"
I called Jim Krantz 2day. he's 79, sold all parts , has tooling, has two olds powered units for sale , non finished $16K for the pair. said he wanted to drive one across America and go fishing, but says he's to old now.
nice guy.
slant six's RULE!
http://www.usajon.com
PostPosted: Tue Aug 23, 2011 8:23 am
Had a friend that used to have an Olds powered one.
Don't the slants use a side draft intake?
