It is currently Tue Jun 09, 2026 4:24 am
 Post subject: changing the u-joints
PostPosted: Tue Aug 30, 2011 8:02 pm
Hey everyone I have a 1975 dodge dart, 225 and need to change the u joints. Is this something I could do on my own or will I need a shop to do this repair? It does not seem to hard but not sure how to go about it. Any help would be great! Thanks
"Dan rocks!"
PostPosted: Wed Aug 31, 2011 5:39 am
You should be able to press out the caps using a bench vice, and a few sockets.
PostPosted: Wed Aug 31, 2011 6:16 am
If you have a decent sized vice, you should be able to do it without too much trouble.
Be careful when you press the new caps onto the "cross" so you don't bend the tiny needles in there :oops:
Get the caps pressed until they juuust about hit the cross, and slide the cross into both caps, if you see what I mean.
I have no idea what I am talking about.
PostPosted: Wed Aug 31, 2011 6:36 am
I broke 2 vices trying to do this. Got a Harbor Freight tool for ball joints.
PostPosted: Wed Aug 31, 2011 9:10 am
When I last took my driveshaft to a shop to get the universals pressed out, they took it in back and beat the stuffing out of it with a big hammer. After that I always did it myself. If the vise isn't enough to get the old one out, I use a big ball peen hammer and a drift, alternating sides, to get the old one free. My 6" vise always works fine for installing the new ones.
PostPosted: Wed Aug 31, 2011 11:25 am
I have a small bench vice that might work, if I need to use it to get the new ones on. Should I replace the oil seal on the trans as well? Does any one know the correct size u joint? I'm seeing 2 different sizes for my car at auto zone. Thanks for all your help guys I'm going to do this, this week so ill keep everyone posted. Thanks!
PostPosted: Wed Aug 31, 2011 11:45 am
Most likely the "7260 "small" u-joint. (2 3/8 wide)
I don't change seals unless they are leaking.
PostPosted: Wed Aug 31, 2011 12:04 pm
6 Pack Dart
"I have a small bench vice that might work, if I need to use it to get the new ones on."
If your vice is too small, you can use a large "C clamp"
Richard
PostPosted: Wed Aug 31, 2011 6:40 pm
Ok so my shaft hooks up to the hub yoke in the rear and it looks like two clamps are holding the cross in. Do I remove the clamps or is there another bolt I'm not seeing? If I remove the clamps how do I re fit the cross back in to tighten down properly?
PostPosted: Wed Aug 31, 2011 7:36 pm
6 Pack Dart
Remove the clamps, when you do and pull the drive shaft you can see the u-joint caps fit into the flange to keep them centered.
Richard
PostPosted: Wed Aug 31, 2011 8:46 pm
When re installing when should I put on the retainers? After I screw back the clamps or before?
PostPosted: Wed Aug 31, 2011 9:21 pm
6 Pack Dart
Before, they keep the u-join held together.
Richard
PostPosted: Fri Sep 02, 2011 7:17 am
Ok put the new u joints in, in about a hour. It fix the vibration problem and was very easy to accomplish never having done it before. Thanks for your help now just got to do the engine mounts. 8)
PostPosted: Fri Sep 02, 2011 11:10 am
"I broke 2 vices trying to do this. Got a Harbor Freight tool for ball joints."
I have yet too break either my 3 lb sledge nor piece of railroad rail
PostPosted: Fri Sep 02, 2011 1:18 pm
I ruined a good Williams Bros. socket with a 3lb sledge changing a U joint.
Users browsing this forum: Bing [Bot] and 5 guests
