It is currently Thu Jun 18, 2026 12:21 am
PostPosted: Fri Sep 02, 2011 11:26 am
hello every one, does any one know if i can buy a new throttle plate new for a carter BBD. i know i can fix it . but just wondering if i could buy one.
PostPosted: Sat Sep 03, 2011 12:47 am
You can get throttle shaft bushing tool from carbjunkys on ebay, they may have throttle plates too, only a phonecall away.
Olaf.
Aspenized
 Post subject: no they dont
PostPosted: Sat Sep 10, 2011 8:50 am
well thanks for the tip but they were not able to help. well i sent my shaft out to a recognized machine shop and he rebushinged the throttle plate. and i got it all buttoned up on the /6 and bam its actually leaking worse than before. FML. it doesn't look like a profesional job to me the holes still look oval and there is still significant throttle shaft play. so i hooked up with a nother guy that works at a chrysler dealer ship. and im taking it to him on monday at lunch. hopefully he fixes it though i do know that the teflon coating on the shaft is worn down were it rides in the throttle plate. so thats probally bad but . for future reference be very detailed when you get stuff machined.
PostPosted: Sun Sep 11, 2011 6:41 pm
Why not, they have the kits!
Carburetor-5-16-Throttle-Shaft-Bushing-Tool-Repair-Kit
and
Carburetor-3-8-Throttle-Shaft-Bushing-Tool-Repair-Kit
The 5/16" Throttle Shaft Repair kit will service:
Rochester Quadrajet, DualJet and Varajet
Rochester 2G, 2GC, 2GV
Rochester MonoJet and Model B, BC and BV
Holley 2245 and other small Holley 2 barrels
Carter BBD
The 3/8" shaft repair kit will service most carburetors with 3/8" shafts. These include:
GM TBIs
Carter Thermoquads
Holley 4-barrels (including muscle car carbs)
Ford (Autolite) carburetors and more.
Always measure the shaft before ordering, the applications listed above are copied from other sources, and may not be correct.
Olaf.
Aspenized
