It is currently Sun Oct 11, 2026 8:40 am
Post new topic  Reply to topic  [ 36 posts ]  Go to page Previous 1 2 3
PostPosted: Sun Nov 14, 2010 2:06 pm
PostPosted: Sat Sep 24, 2011 5:00 am
hi dadtruck, i think this piston post and the pictures will help you. ron
PostPosted: Sat Sep 24, 2011 1:42 pm
thanks
the Sealed Power brand is Federal Moguls after market name,,
FM has a great reputation for pistons,, but being also an automotive OE supplier I bet they will design aftermarket part structurally, to OE requirements.
I did go with Sealed Power rings, I know that the rings were made at the FM Manitowoc WI plant that I have worked with in the past.
I chose the KB- Silvolite pistons on a belief that they are 100% aftermarket with a racing - high performance back ground company. My guess is their designers would tend to over design for strength..
I think the thicker skirt walls show that.
PostPosted: Sat Sep 24, 2011 3:04 pm
doug i thought that the metal insert had a different exspansion rate than the surounding aluminum and was undesireable for racing,am i wrong in thinking that? i am using the seal power from summit now in the blower motor and have had no problem , except melting one from a bad tuneup. :roll:
PostPosted: Mon Sep 26, 2011 4:58 pm
I use forged pistons in a true race engine.
I have used a lot of cast w/ steel strut pistons in "street performance" engines with-out problems. (the factory pistons use this design)
I have seen some "no strut" pistons offered for the SL6 and a few of those with the complete piston top broken-off at the oil return ring groove. :shock:
PostPosted: Tue Sep 27, 2011 1:52 am
i will have to rethink what i have :?
Users browsing this forum: No registered users and 22 guests
