It is currently Sat Jun 13, 2026 7:11 pm
Post new topic  Reply to topic  [ 43 posts ]  Go to page Previous 1 2 3
PostPosted: Fri Sep 23, 2011 4:47 am
For winter in Toronto you need special tires, sand, salt, shovels, rustproofing, twelve layers of clothing, a whole hell of a lot of whatever you burn to heat your home…shall I go on?".
YES.
Get it all out Dan; exorcize the beast.
I’ll prime the pump: crappy winter street parking conditions; removing snow from roof; icicle control; unscheduled heating equipment service; ice storms; power outages; below zero wind shield scraping --- now you run with it.
OK… OK…
Now take a cleansing breath; breathe in deeply and slowly through nose, hold it, hold it, hold it--- Now slowly exhale through mouth.
Better now?
You’ll feel even better once unpacked, and can find your bumbershoot.
LOL
Bill
PostPosted: Tue Sep 27, 2011 10:48 pm
Ah, Vancouver... Where you can drive your classic slanted vehicle year round, as long as it keeps water out, & has good wipers. The lack of intermittent wipers can be a tad annoying, that's about it. Dan, what area of Van did you move to?
PostPosted: Wed Sep 28, 2011 12:14 am
An undersatisfactory, overpriced, stanky basement apartment pending real housing.
PostPosted: Wed Sep 28, 2011 12:52 am
:lol:
Dan said "stanky.". C'mon Dan, we've all been there!
PostPosted: Wed Sep 28, 2011 1:17 am
Yeah, but I only said it's stanky 'cause it's stanky.
PostPosted: Wed Sep 28, 2011 5:41 am
SSD:
Sounds dreamy.
PostPosted: Wed Sep 28, 2011 9:28 am
I've got a brand newish 1 bedroom Condo on the Surrey/North Delta Border you could rent. It's fully furnished and has a 50" Plasma tv in it. On the top (4th) floor.
Well, it was rented for 5 months by a single woman, so it was barely lived in.
PostPosted: Wed Sep 28, 2011 9:34 am
........Surrey! .......or mebbe Kerrisdale........
PostPosted: Wed Sep 28, 2011 11:08 pm
I'd agree with you in a hot second, Sandy, but it has to be in Vancouver, otherwise no foot traffic to Bill for photo shoots (see "galleries"). And he doesn't drive, so out in the 'burbs wouldn't work.
I just(!) flew back from Germany. Day after tomorrow we sign the lease on a purty nice place at Howe and Davie.
Jester, thanks for the offer!
PostPosted: Thu Sep 29, 2011 5:35 am
Well there goes that swanky Man Cave…
PostPosted: Thu Sep 29, 2011 7:06 pm
...undersatisfactory, overpriced, stanky basement apartment...
seems to be the case with most vancouver accomodations, at least the overpriced part:)
on a note related to the beginning of this thread, when peering down into the carb and turning the throttle, seems that when turning quickly i see a solid shot of fuel, when turning slowly, the fule seems to dribble out.
is this what you refer to earlier dan? accelerator pump working crappy?
Franklyn
1965 Dart GT - 1949 Plymouth Special Deluxe
PostPosted: Thu Sep 29, 2011 7:28 pm
Well, how slowly is "slowly"? The shot will be strongest when you open the throttle quickly. It will be less vigourous when you open it slowly. If you want to check for sure, remove the link that connects the throttle lever to the accelerator pump lever, then push the rear of the accelerator pump lever down and then let go of it as you watch the stream. It should be strong and solid. If it's weak, you will want to go through the carb and perhaps stretch the accelerator pump spring slightly for stronger pump action -- keep in mind it is the spring, not the throttle opening itself, that pushes the plunger.
PostPosted: Thu Sep 29, 2011 8:52 pm
Doh! I supersixed a perfectly good 1920 for the dead spot issue. I bet stretching the accelerator pump spring would have solved my problem :D
Dan, the place is there if you need it, with a slanters discount. Going to advertise it on the weekend. A short bus ride to Scott Road station skytrain.
Users browsing this forum: Amazon [Bot], Google [Bot] and 4 guests
