It is currently Wed May 27, 2026 8:16 pm
PostPosted: Thu Sep 29, 2011 12:52 pm
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
At what point do I need to go to a higher octane? I have a 9.5:1 ratio on my current engine, but I'm runnning propane, which is 108 octane.
Planning on building another petrol engine....
Thanks,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Thu Sep 29, 2011 1:45 pm
An 8 to 1 DCR (Dynamic Compression Ratio) is about the max for 87 octane pump gas.
PostPosted: Thu Sep 29, 2011 3:31 pm
THanks, Doc. Is that about what stock is?
Joe
Joe Hoppe
 Post subject: Lol...
PostPosted: Thu Sep 29, 2011 4:44 pm
I've gotten away with a bit more at 8.23:1 DCR but had to yard the timing back which makes for a gain and a loss (kept the mileage, but I'm sure I left some power out of it...), that engine was 10:1 SCR...
DCR is a more accurate way to check how your engine is going to possibly perform, there are several calculators online to help. SCR
is what is typically is used (stock mill is advertised in the 8.2:1+/- range, but can be anything depending on the year and vehicle).
PostPosted: Thu Sep 29, 2011 4:45 pm
The DCR from the factory is usually in the 7.5 to 7.8 range.
PostPosted: Fri Sep 30, 2011 6:50 am
So a thinner headgasket would probably be the safest and farthest you'd want to go as far as compression mods if you wanted to keep using regular?
Joe
Joe Hoppe
PostPosted: Fri Sep 30, 2011 9:28 am
Measure, calculate and set your static & DCR compression ratios... or ...
Make your "best guess" and take your chances.
The "best guess" with a factory SL6, give it more compression.
Using a stamped steel shim head gasket helps but not a lot... and you need really clean & flat surfaces to get those to seal well.
My best "guess"... mill the head to get a 50 cc chamber size and use a Fel-Pro gasket.
PostPosted: Fri Sep 30, 2011 12:50 pm
Thanks again, Doc.
Joe
Joe Hoppe
