It is currently Wed Jun 17, 2026 2:26 am
PostPosted: Fri Sep 30, 2011 6:51 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Any tips? Looks like they are spotwelded, as opposed to being bolted on, as is the case w/ my D100.
Thanks,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
PostPosted: Fri Sep 30, 2011 2:19 pm
Not really sure why they would be. Maybe there's a bolt somewhere you missed? Also they used some kind of weather striping on the fenders to reduce rattle. After 40+ years it kind of looks like glue and works like it. A rubber mallet works to knock the fender loose. Also there's a stud inside the fender below the A-pillar.
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
 Post subject: Where?
PostPosted: Fri Sep 30, 2011 5:22 pm
Where is it tight? The fenders should unbolt and not be welded in place. Not sure about your year but the earlier A bodies have a bolt/Stud at the far rear of the fender that has to be unbolted, up from the bottom with the door open, or with the splash shield removed and go up under the fender. Give us a little more detail.
Rick
PostPosted: Sat Oct 01, 2011 5:45 am
my 1968 HT bolted right off/I think 1967's r the same
I did remove doors to get to the lower rear botl to make it easy
an dmake repaires on the doors too.
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Oct 02, 2011 1:15 pm
That's how i've done it to.
Apparently it's easier to remove the splash shield without removing the door.
PostPosted: Sun Oct 02, 2011 1:37 pm
You can also stand on your head, and act like a contortionist and take a long extension or 2 with a deep well socket and a universal joint and go up between the fender and door. Not the easiest but it can be done.
Rick
PostPosted: Tue Oct 04, 2011 3:15 am
I believe you. I tried getting about 3.5 feet of extentions on the ratchet that way the ratchet is down below the fender between the door and the series of extensions can bend.
