It is currently Sat Jul 18, 2026 12:19 pm
PostPosted: Sat Sep 17, 2011 6:03 pm
Mike built my head and made the call on the cam.He also gave me his blessing on going for his record.Without him I dont think I would have any records.Guzzi Mark
PostPosted: Thu Sep 29, 2011 8:37 pm
Got 95% of the nitrous stuff to install in the car,figure it will weigh about 35lbs heavier with the trans blanket that I hope I need to run in the 10s.Started cutting car AGAIN to lose 40lbs so I can go for the A nitrous record.Cut rockers and doors and replaced steel with 7075 aluminum.Spent over 8 hrs on ONE side and only lost 3 lbs.Going for bigger chunks.I figure about anouther 100 hrs I will have close to the weight out of it I want.I am a record whore.I figure the next two I go for will cost about $2,000 and about 200 hrs labor.Forgot about the new 4.30 spool add anouther $600.I eat Banquet tv dinners so I can afford the car.Guzzi Mark
PostPosted: Thu Sep 29, 2011 9:42 pm
6 Pack Dart
Mark you might loose some weight eating that stuff :lol: :lol:
Richard
PostPosted: Fri Sep 30, 2011 3:38 pm
You don't need food, just the machine addiction will keep you going...
