It is currently Mon Oct 12, 2026 4:14 am
 Post subject: Thoughts on this carb?
PostPosted: Tue Sep 27, 2011 7:18 am
http://cgi.ebay.com/ebaymotors/1962-PLY ... 4aaef155a2
65 4 dr. Valiant 200
PostPosted: Tue Sep 27, 2011 7:33 am
Almost certainly needs a rebuild, but I'll take it over a parts store rebuilt unit any day and rebuild it myself (if I were still running carbs). Even if you have no carb rebuilding experience whatsoever, it would be difficult to do as poor a job as the companies that supply parts stores with their rebuilt carbs.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Tue Sep 27, 2011 7:55 am
From little experience I have it looks all right, looks in the same condition the original carb on my car had which had easily been around the clock 2 - 3 times. Find a good rebuild kit from a decent supplier and go ahead. I'm sure SSD will chime in with a full response!
PostPosted: Tue Sep 27, 2011 8:42 am
Probably a relatively good candiate for a rebuild, but still a bit of a gamble; could be corroded inside beyond effective cleanup. Also, it's from a pre-1967 170 engine and so is a really small carb (smallest venturi, small throttle bore). It is equipped for PCV, so the car was a California or New York unit or was ordered with PCV which was not standard equipment in all the states until '63.
PostPosted: Tue Sep 27, 2011 6:48 pm
So am I better replacing a jacked up choke, various old and worn out parts and all the old springs and such that can "plug and play" so to speak?
PostPosted: Wed Sep 28, 2011 12:15 am
Um…
Operator?
PostPosted: Wed Sep 28, 2011 5:31 am
I thought '65 was the PCV year on Mopars?
PostPosted: Wed Sep 28, 2011 6:23 am
California cars got PCV instead of road draft tube starting in '61. New York starting in '62. Nationwide + export for '63.
The breather inlet was originally vented to atmosphere. Starting in '64 (California) and '68 (nationwide + export), the breather inlet was ducted to the carburetor air cleaner.
This holds for all makes -- not just Mopars.
PostPosted: Wed Sep 28, 2011 11:02 am
If that is true the BBS on the '72 slant I just bought is really old!
Ok I remember where I got '65 from. 65 was the year the SB BBD's got a wire and stud to mount the air cleaner.
PostPosted: Wed Sep 28, 2011 11:05 pm
Show us a picture.
'66, except on Barracudas which got it in '65.
PostPosted: Fri Sep 30, 2011 8:05 pm
Digicam crapped out. I'll get the GF to take a pic and I'll email it to someone.
Users browsing this forum: No registered users and 33 guests
