It is currently Wed May 27, 2026 2:01 am
PostPosted: Tue Aug 23, 2011 8:20 am
I have a brand new brake booster and master cylinder from a 73 4 door Valiant. Will this go into a 67 Valiant with manual brakes? I believe I need the rod that goes from the brake pedal to the MC but do I need anything else?
PostPosted: Tue Aug 23, 2011 8:31 am
It'll go right in. Which master to use will depend on which brake system the '73 items are for vs. what your '67 has. You'll need new lines from the master to the splitter block -- and make sure they do a loop-de-loop to allow for flex.
PostPosted: Wed Aug 24, 2011 1:40 pm
Thanks Dan, I have a couple questions.
What do you mean by which master to use will depend on which system the 73 items are for vs what the 67 has? The master cylinder and the booster came off the 73 as an item and I know they were both working correctly. Will I possibly have to swap the master cylinder with a 67 with power brakes master cylinder?
Also, good call on the brake lines. I've never had to mess with the metal lines before. Do they have to be custom made or can you buy them made to fit?
PostPosted: Sat Aug 27, 2011 6:23 am
Stupid Question: An actual loop de loop with say a radius of 1" etc? I don't think my car has one... or is excess piping in some other formation?
PostPosted: Sat Aug 27, 2011 6:47 am
I mean, what brake system has your '67 got? 9" drums all around? 10" drums? Front discs? And what brake system did the '73 have? You have to match the brake master cylinder not only to the brake system the car has, but to the presence/absence of a power booster.
It may be possible to buy them ready-bent -- check with outfits like www.inlinetube.com who usually sell only whole-car brake line kits and tell them you're adding a brake booster and need the master-to-prop-valve lines -- or you can buy a length of steel brake line and a tubing bender from a parts store, or you can buy six feet of 3/16"Cunifer line and the appropriate end nuts and bend 'em up without a tubing bender.
The loop radius ought to be about 2".
PostPosted: Mon Aug 29, 2011 11:51 am
As always, you hooked me up with all the information I needed. Thanks again Dan!
PostPosted: Mon Sep 26, 2011 1:26 pm
Dan, one last set of questions just to be sure.
On Rock Auto I'm not finding a 74 or 75 master cylinder for front and rear power drum brakes. They do have a 67 master cylinder listed here but it doesn't say 9" or 10" brakes. It does say for power drums though.
http://cardone.com/English/club/members ... UM=10-1323
So in the end, I can match up
74 Brake Booster
67 Master Cylinder for power drum brakes
Then just make the lines from the new master to the prop valve.
Correct?
PostPosted: Mon Sep 26, 2011 3:29 pm
Cardone is junk -- don't buy.
Get a Wagner MC36439, Bendix 11573, Centric 130.63018, or Autospecialty M-83018.
PostPosted: Wed Sep 28, 2011 1:33 pm
Thanks, I'll use those part #'s. Cardone looked shady just on the price alone.
PostPosted: Fri Sep 30, 2011 8:05 pm
Saying that Cardone stuff is junk, well, - that's an insult to junk!!
63 Valiant Wagon
225 - 4 bbl
PostPosted: Fri Sep 30, 2011 8:18 pm
That's my experience -- Cardone's stuff is bad garbage, start to finish. Richard "Mopar Action" Ehrenberg disagrees with me; he thinks Cardone stuff is great.
Users browsing this forum: Ahrefs [Bot] and 3 guests
