It is currently Sat Jun 13, 2026 6:06 pm
PostPosted: Sat Oct 01, 2011 5:49 am
Ok
Im thinking any tips on how to make your slant six theif proof?
I do have insurance/but we like being safe/not sorry.
it is parked outside in drive way..and I have had to start it with the wire/screwdriver u know..
thanks for any tips in this area...
slant six's RULE!
http://www.usajon.com
PostPosted: Sat Oct 01, 2011 2:28 pm
Hidden toggle switches
PostPosted: Sat Oct 01, 2011 4:05 pm
Dont do hidden switches. Thats what thieves look for first. If you can, use switches that look like a factory switch for ignition and starter and keep them in the open and unlabled. I have 4 rocker switches on my dash, 3 for lights and the forth is to turn my coil on and off. Its in the middle and none of my switches are labled. You can crank the engine over all day long but if the coil switch isnt on it wont start.
Here is a bosch relay guide that has quite a few security things that are easy to do with a bosch relay. http://dlcparts.com/images/BoschGuide.pdf
Old truck: 82 D150 225, 2bbl, dutra duals, 2.5" straight pipe to dual 2.5" tail pipes. Mud tires, 4spd, old forest service truck.
Current truck: 98.5 Ram 2500 ccsb, sport, 24v cummins, 5spd, 4.5" lift, 35's, 5" straight pipe.
PostPosted: Sat Oct 01, 2011 5:51 pm
How 'bout some vintage anti-theft ideas to go with the vintage car? Look here and here (though read the clarification note here and note that this one works only if you're smart enough not to smoke). More ideas here.
Or just drive a pre-'65 automatic car with pushbutton drive. In this day and age, it's a very effective measure against drive-off thieves, who might start it but will likely never figure out how to get it shifted into Drive.
PostPosted: Sat Oct 01, 2011 6:42 pm
If you want cheap,pull the coil wire off and put it in the house when done driving.
PostPosted: Sun Oct 02, 2011 2:42 am
Rewire the cigarette lighter to be the ground for a relay that runs the ignition.
Car will crank and crank without the lighter pushed in, but won't start.
:D
- Mac
PostPosted: Fri Oct 07, 2011 9:27 am
:D
- Mac
Awesome!
PostPosted: Sat Oct 08, 2011 9:21 am
Low tech: pull any plug wire out of the distributor cap, and switch it with the center wire from the coil. It looks like all the wires are connected, but won't start.
Also on one of my cars, the battery was moved to the trunk by PO. If the area is sketchy, I just remove the ground from the battery and close the trunk lid.
PostPosted: Sat Oct 08, 2011 11:45 am
Buy a Honda Civic and park it next to your car. They will go for the Civic and ignore your "good" car.
PostPosted: Sat Oct 08, 2011 12:02 pm
Er, not to be too obvious, but how about an alarm? I've had one on my car for 10+ years.
Don't use it in SoCal, but when I'm in Nevada, it's always in use :)
PostPosted: Sun Oct 16, 2011 8:26 pm
This is true.
When i was getting a roadworthy certificate on my 63 Valiant wagon a while ago,the young kid working there asked me to drive it on the ramps for him because he couldn't figure out how to get it in gear.
:roll:
DRIVE IT,DON'T HIDE IT
PostPosted: Sun Oct 16, 2011 11:11 pm
Put a tiger in the back seat.
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Mon Oct 17, 2011 6:03 am
Oh exojjl, that’s just silly, every old guy here knows the tiger always went in the tank.
Classic oiling
PostPosted: Tue Oct 25, 2011 5:41 pm
Perhaps a trunk monkey. (youtube)
PostPosted: Tue Oct 25, 2011 5:52 pm
+1
