It is currently Mon Jun 01, 2026 11:01 pm
 Post subject: Balancer
PostPosted: Thu Oct 06, 2011 7:09 pm
Hi I have a 67 d100 , i was told that I have a forged crank and is uses a different balancer that /6 with a cast crank , thanx for any info
Dodge =Dam Old Dodge Goes Everywere
PostPosted: Fri Oct 07, 2011 4:03 pm
No, the difference is in the placement of the timing marks. IIRC, they changed in the late '60's, so you will need an early damper.
A cast crank damper will fit/work, but your timing tab will not align with the mark on the late damper. :D
PostPosted: Sun Oct 09, 2011 1:57 pm
Thank you ,I did want to use one that was harmful to the motor
Users browsing this forum: Google [Bot] and 15 guests
