It is currently Sat Jun 13, 2026 8:59 pm
 Post subject: 1231 Choke Kit
PostPosted: Tue Oct 04, 2011 8:23 am
Just ordered this...start praying for me. :?
65 4 dr. Valiant 200
PostPosted: Fri Oct 07, 2011 8:08 am
Wow, they werent kidding about "a couple of days"...just arrived today.
PostPosted: Fri Oct 07, 2011 9:17 pm
Wow, that went much easier than I thought it would...electric stuff and I usually don't get along. :lol:
After installing it it took the idle down like it should by itself when it warmed up and them started (and raised the idle) when cold. ALL BY ITSELF!!! This is a big deal for me...no more having to open the hood every time I want to cold start it. :D
A few quick things...
1- Does anyone have pictures of what they did with the wires? Just curious if what I did is the most efficient way (very likely it's not).
2- Where did you place the temperature sensor?
3- Did anyone else have trouble with the hole location on the mounting bracket? I centered the passenger's side hole and the drivers' side hole was off. It was easy enough to fix by turning the circle into an oval with a drill...just curious if this was an issue with these folks in the past.
All in all, a huge success...a big deal for me too. I recommend this kit very highly...almost as highly as Dan does! :D
