It is currently Thu Jul 16, 2026 10:40 am
PostPosted: Sun Oct 09, 2011 2:00 pm
stock diameter slant six lifter is .904 I have read
has anyone ever run a 1 diameter lifter..
can a 1 inch diameter overbore on a slant six lifter galley be done/safe?
slant six's RULE!
http://www.usajon.com
PostPosted: Sun Oct 09, 2011 2:01 pm
lol so you saw my thread eh?
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Sun Oct 09, 2011 2:06 pm
where
point me
so you have run this ?
how do you like it?
my neighbor is building a blown hemi small body charger and he has this hi-tech info all the time
carbon fiber disk brake rear end etc...
slant six's RULE!
PostPosted: Sun Oct 09, 2011 4:13 pm
With the advent of roller lifters there really is no advantage to going to a bigger lifter anymore. Besides, anything over .600" lift on a Slant is pretty much useless since we don't have the flow capabilities in the head. :?
PostPosted: Sun Oct 09, 2011 4:48 pm
There's a roller available for a slant?
PostPosted: Sun Oct 09, 2011 4:49 pm
cost factor may be a big differance..
slant six's RULE!
PostPosted: Sun Oct 09, 2011 5:43 pm
yes... its 1K just for the stick...
PostPosted: Sun Oct 09, 2011 5:44 pm
no but it will allow you to run a big enough cam to stay away from roller rockers... and the end goal is .550 AFTER lash...
PostPosted: Sun Oct 09, 2011 7:21 pm
.904 is plenty big for that. I know someone who has been over .600" with a 904.
You could always bore just the bottoms and use mushroom lifters.
PostPosted: Sun Oct 09, 2011 8:51 pm
well yea but if you dont want a whole bunch of duration then you cant get under about a 252 @ 50 528 valve lift or so...
 Post subject: Lol....
PostPosted: Sun Oct 09, 2011 9:39 pm
Oregon Cam Grinding Intake Lobe #1192...231@050 .558 lift@1.5
And slants need a certain amount of duration to allow enough flow through the restrictive ports....I already tryed the high lift short duration cam...works good if you keep your rpm over 2500...probably would work better if the engine had boost.
:wink:
Funny, mine cost me $250...of course it won't work on the street... :lol:
PostPosted: Sun Oct 09, 2011 11:01 pm
http://victorylibrary.com/mopar/roller-adapt-c.htm
slant six's RULE!
 Post subject: Re: Lol....
PostPosted: Mon Oct 10, 2011 6:41 am
well yea it likes a high rpm due to the fact you have 25x degree's of duration... probably make peak power around 6300 i would think...
:wink:
i was just passing along the number that i was quoted...
