It is currently Sun Nov 15, 2026 4:37 pm
PostPosted: Mon Oct 10, 2011 4:50 pm
Ray, take a look near the bottom of the Forum Index, there you'll find a section 'How to use this forum', which - among other useful info - contains a recipe for use of pics in the forum.
Olaf.
Aspenized
PostPosted: Wed Nov 16, 2011 5:39 pm
Sorry guys not had a chance to get a few pictures of this modification ,had a rear spring snap on me 2 weeks ago so that was my first priority, Now i have a timing question. I set up the Hemi Elec dissy the same as I would for the original pionts dissy , vacuum advance disconnected, idling at 750 RPM and timing set to 2 1/2 deg BTC but after doing a 600 mile trip not quite right, Any thoughts on what timing should be ? RAY
PostPosted: Wed Nov 16, 2011 6:20 pm
6 Pack Dart
Try bumping it to 10 or 12 degrees.
Richard
PostPosted: Thu Nov 17, 2011 12:21 pm
Will give that a go Richard I was note sure why the later 225's have a different timing set up? RAY
PostPosted: Thu Nov 17, 2011 12:47 pm
6 Pack Dart
For cleaner air ??
Richard
PostPosted: Thu Nov 17, 2011 2:10 pm
Doubt that is it maybe the cam is different after 66?, RAY
PostPosted: Sun Nov 27, 2011 2:37 am
Sorry guys not had tiem to get photos yet, we took the Valiant away fro a weekend trip did over 500 miles and went well, had a few other issues since so been side tracked, broke a rear spring ( some moron had removed a leaf ) and the rear seal on the gear box went so had to fix that, but other wise the Hemi elec ignition is all good. RAY
