It is currently Wed Jun 17, 2026 12:20 pm
 Post subject: setting up Holley 2300
PostPosted: Thu Sep 29, 2011 9:06 am
I'm trying to set up a Holley 2300 for my car. Soaked in solvent for several days, sprayed carb cleaner through all the passages, new gaskets, etc.
The problem I'm having is that under normal conditions I can't get anything out of the pump discharge nozzles. If I repeatedly pump the accelerator pump real fast, I can get a weak shot. I've double and triple checked that the passages are clear. Do I need a different sized pump cam? I'm running the biggest one I had, though I don't recall the number on it off hand.
Pump discharge nozzles are 35s, and swapping out different strength accelerator pump diaphragms didn't affect anything. Any pointers would be appreciated.
PostPosted: Thu Sep 29, 2011 9:28 am
Car Model: 64 Valiant
Did you replace the diaphram in the pump?
PostPosted: Thu Sep 29, 2011 9:30 am
It sounds like the check ball(s) are missing or not sealing well. (#25 & 89)
http://www.holley.com/data/TechService/ ... 20View.pdf
Inspect the check balls for a smooth surface and also look at the condition of it's seat.
Also check the gaskets at the metering plate & float cover to be sure you are getting a good seal around the pump shot passageway at those points.
PostPosted: Thu Sep 29, 2011 9:48 am
Online
DD:
Holley often supplies several gaskets to service a number of different carburetors in their rebuild kits. One has to be carful to match up their new gasket with the exiting gasket. There are subtle differences in them, and one of the areas to look for is the placement of the accelerator pump passage so that it lines up with a hole in the new gasket.
 Post subject: Yep...
PostPosted: Thu Sep 29, 2011 4:53 pm
1) Check the pump per Doc, if you have an old Holley it will have a captured ball, if it's newer it will have the rubber umbrella valve seal.
2) Check the gasket holes per Wjajr, this is important, not all Holleys
have the same port features in the throttle body and plates.
3) Qualify the pump stroke...the lever that is moved by the pump cam, has a spring loaded end that moves the pump lever, if you pull the throttle lever to full open the lever should allow you to put a .015 feeler
gauge between the end of the spring loaded bolt head and the pump housing lever with a bit of resistance( like lashing your valves), if it's to easy, you need to take up the slack until it's correct. That will ensure you are getting the full "pump" out of the pump.
PostPosted: Mon Oct 10, 2011 9:20 pm
Finally remembered to check out the carb. while at my buddy's shop tonight.
There are not provisions for check balls in either places shown on the diagram. Gaskets and passageways have been checked and triple checked. Pump stroke was adjusted several different ways across the spectrum while on the car, without any change in pump shot. We are stumped...
PostPosted: Tue Oct 11, 2011 8:45 am
There has to be "one-way" check valves somewhere in acclerator pump system. (There are ususally 2, one is the "gate" for incoming fuel, into the pump, the other is between the pump and the discharge nozzle(s)
Keep looking...
