It is currently Mon Jun 22, 2026 3:44 pm
PostPosted: Sat Oct 15, 2011 5:12 pm
So far, I've been removing the lash adjuster from the rocker arm, screwing a thin locknut onto it and then doing the obvious, locknutting it in place.
Since I got the motor running 3 months ago, I'm up to 4 with that treatment.
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Sat Oct 15, 2011 6:39 pm
You can squish the arms in a vice to make things a little tighter.....or if the reason they are backing off is a lot of meat milled off the head or deck....you can use shorter pushrods.
PostPosted: Sun Oct 16, 2011 1:40 am
Mine are just loose from age and many movements, apparently. I don't have a vice, and taking off the rocker arm to do that seems like a pain.
Years ago, my poly 318 had the same problem, but those were cast rockers, no squeezing them was possible. I ended up using a washer under the hex on top and it just happened to make it tight at the proper clearance.
I've been quoted $50 + shipping for a rebuilt rocker arm assembly, but how are they "rebuilt"?
PostPosted: Sun Oct 16, 2011 5:44 am
3/8" fine tread jam nuts is another way.
PostPosted: Sun Oct 16, 2011 10:22 am
that's what I used.
PostPosted: Sun Oct 16, 2011 4:49 pm
the adjuster set from isky for a 426 hemi work... they have a lock nut and allen head...
they are a little tall with higher lift and hit the baffle but thats an easy fix...
think 1.25" long
1965 Plymouth A/FX 512ci (under construction)
1968 Dodge Dart SL6 14.25 @ 91.5 1.91 60'
1973 Dodge Dart SL6 Stock
Killer Bee's Member Since 09'
http://www.forabodiesonly.com/mopar/sho ... p?t=128702
http://www.youtube.com/user/805moparkid
PostPosted: Mon Oct 17, 2011 5:35 am
green locite on the treads help alot.
PostPosted: Mon Oct 17, 2011 10:07 am
BTW, how do you live w/o a vise? Since age 5, I think I was without one for a couple of months around age 25, and I almost went mad...
PostPosted: Mon Oct 17, 2011 10:45 am
I know, right? Mine are cigareets and whiskey and wild, wild women.
PostPosted: Mon Oct 17, 2011 12:41 pm
I used to be a mechanic... worked in a diesel shop for 13 years. Now, I have no shop, I lost all my tools ( 3000 worth of Snap hand tools alone) to theft, I don't even have a carport to work under.
So, sorry, no vice. It's a pain, but I rent and have no choice.
PostPosted: Mon Oct 17, 2011 12:47 pm
Wow, that is terrible.
When I had just a carport in a rental apt in SoCal (6 yrs), I got a hold of an old army footlocker and bolted a Sears vise to it, then filled it with 250 lbs of rear axle and engine parts and locked it. Nobody gonna walk off with that.
PostPosted: Mon Oct 17, 2011 4:41 pm
my car came with the jam nuts already installed, being a mopar newb, i thought they were suppose to be there. the vw's have them, those germans sure know how to build a motor ;-) theres never a adjuster problem, unless you buy cheap unhardened adjusters from EMPI and they get eaten away in less then 5 minutes
