It is currently Mon Nov 16, 2026 12:09 am
 Post subject: Coolant oil etc sensors
PostPosted: Tue Sep 23, 2003 4:32 am
Does anyone have the charts of what the resistance vs quantity measured of any popular sensors out there (including the stock A body sending unit), wether they are mopars or not? I know www.diy-efi.org had them for the GM sensors but untill they are back up.....
I believe the stock sending unit is linear so if someone has one not in a tank, I would appreciate it if you could measure the resistance when in full and empty positions.
This is all to add to the bundymobile tach in hopes of possibly making it a full blown digital dash. I've just recently added a voltmeter to it, getting just one step closer at a time.
PostPosted: Tue Sep 23, 2003 7:13 am
fuel sender was 96 ohms and 0 ohms
I don't remember which was F and which was E
I can check again with the one bench tonite.
I finally checked - 86 empty and 8 full -
And not linear the windings are longer and closer
together from about half down to empty.
PostPosted: Tue Sep 23, 2003 9:56 pm
A quote from http://auto.howstuffworks.com/framed.ht ... .html#faq1
Here are a few other thoughts to help match the ohms of the sender to the gauge:
GM cars (most) are 0-30 ohms [empty - full] prior to 1965
GM cars (most) are 0-90 ohms [empty - full] 1965 to present
Ford cars (most) are 16-158 ohms [empty - full] 1987 to present
Ford/Chrysler cars (most) are 73-(8-12 ohms) [empty - full] prior to 1987
Studebaker cars (most) are 240-33 ohms [empty – full] unknown years
VDO kits are 10-180 ohms*
Auto Meter kits are 240-33 ohms*
Stewart Warner kits are 240-33 ohms*
Classic Instruments, Inc. kits are 240-33 ohms*
ISSPRO, Inc. kits will be 240-33 ohms (available: winter 2000)
After market - available in most ohm ranges except 0-30 ohms.
End quote
Pierre: Is this what you need?
I have three sending units for F bodies and all three are 65 - 10 empty-full.
Haynes Repair Manual for Dodge, Plymouth & Chrysler 1971 thru 1980 for A, B, C, E, F, J, M, R bodies says 60 to 75 ohms empty 5 to 8 ohms full (I guess you already know this)
Rafa
Hecho en México
PostPosted: Tue Sep 23, 2003 10:29 pm
Seis,
Yep. Looks like 75 ohms full and 8 ohms empty is the consensus? D*mn, I wish I remember what my unit read. I measured it but never recorded it.
The difference between 5-8 ohms on the low end is almost negligable, I'm just worried about the 60-73 spread. I suppose I can fill my tank up and use the ohmeter at the gas station ;)
Now I just need coolant and oil. The hard part about recreating those is that I don't think they are linear so I may have to do some sort of lookup table on those, hmmm....
Thanks for all the input guys, keep it coming if you can!
PostPosted: Wed Sep 24, 2003 7:52 am
Pierre,
I plotted out the GM temperature sensor in my EFI article. I think that I got the numbers from a table, but I don't remember where I found the table. http://slantsix.org/articles/dibiase_ef ... ersion.htm
Bob D
PostPosted: Wed Sep 24, 2003 7:17 pm
Bob, that graph looks like it was made in excel... any chance you still have the original excel spreadsheet?
PostPosted: Thu Sep 25, 2003 6:40 pm
Pierre,
I found a chart for the GM coolant sensor in a factory '85 Olds service manual. I think it's the chart that I used to do the graph. Here are the values from the chart:
210 deg F ---------185 Ohms
160 deg F----------450 Ohms
100 deg F----------1800 Ohms
70 deg F-----------3400 Ohms
40 deg F-----------7500 Ohms
20 deg F-----------13500 Ohms
0 deg F-------------25000 Ohms
-40 deg F------------100700 Ohms
Bob D
PostPosted: Thu Sep 25, 2003 7:50 pm
Bob - You hit paydirt. That along with curve fitting I can probably get within 5 degrees accuracy.
PostPosted: Fri Sep 26, 2003 6:23 am
That curve for the GM sensor is also on the megasquirt site - maybe in Lance's FAQ manual.
PostPosted: Fri Sep 26, 2003 10:41 am
Coolant temp measurment is up and running!
