It is currently Fri Nov 27, 2026 10:04 pm
 Post subject: Best Quality Clutch?
PostPosted: Fri Dec 26, 2008 9:21 pm
I searched as best I could, but I can't find anything about available quality clutch brands for slant 6 9-1/4" clutches.
Where is the best place to get a clutch / best brand?
Rock Auto sells AC Delco. Any good?
Bob
Robert Troy
69 slant 6 OD4 Barracuda conv
68 383-S 4 speed convertible
PostPosted: Fri Nov 04, 2011 7:20 pm
Bump
:lol:
Robert Troy
PostPosted: Sat Nov 05, 2011 4:58 am
Try to get a new (not rebuilt) unit. I don't know about brands. McLeod used to make a nice one, but likely not anymore.
You might google, and call, Valley Clutch in Irwindale, CA, if they still exist. I bought some nice clutch parts there 10 yrs ago...
 Post subject: Stock or not stock...
PostPosted: Sat Nov 05, 2011 11:10 am
If it's a stock replacement with no "abuse", then you are stuck with LUK or ZOOM. Ive used Zoom 9 1/4" in my rigs with no problem except they will not take repeated hi-po drag style launches. After that you are looking at an aftermarket clutch which there aren't many choices. McLeod would've been the first choice but they aren't making them.
A few people are running SPEC slutches and there are some issues there mostly due to the clutch not able to take repeated drag racing launches, that being said if it's just a daily driver and no racing their Stage 2/2+ should last forever and worked well for daily driving behind a moderately souped up slant...
FYI,
PostPosted: Sat Nov 05, 2011 3:28 pm
This is for a stock replacement for my mileage car. Stock cam, stock everything except Holley Economaster and 2-1/4" headpipe.
What is wrong with LUK? Poor quality? Similar quality to Sachs?
I got on SPEC website and can find no slant 6 clutches. Just small block, and some 383, listings.
Bob
Robert Troy
PostPosted: Sat Nov 05, 2011 8:08 pm
I am running one from autozone in my semi hotrodded 80 D150....some over weight loads,some dragstrip starts....seems to be holding up ...
been a few years now
 Post subject: SPECial order
PostPosted: Sat Nov 05, 2011 9:16 pm
They don't sell as many so they aren't in the catalog the number on my box depending on the type was SD252-2 or SD253-2.
LUK and ZOOM are OK, and luckily are new not "reconditioned"...
for a stock daily driver the NAPA/Autozone special should work fine.
PostPosted: Sat Nov 05, 2011 9:32 pm
Thanks!
Bob
Robert Troy
