It is currently Wed Dec 31, 2025 4:25 pm
Post new topic  Reply to topic  [ 30 posts ]  Go to page 1 2 Next
PostPosted: Tue Nov 08, 2011 12:47 pm
I went ahead and replaced the water pump, I thought that was where the whirring/grinding noise was coming from. I already had one in the garage anyway. However, it's still making that noise. Not all the time though. When I looked at the crank pulleys closer, the one in the middle looks "loose" to me. This is the pulley on the crank that the alternator belt rides on.
I can actually move that pulley forward and backward a bit. Correct me if I'm wrong, but this isn't normal, is it? The other two pulleys are tight, this is the only one that has any play. Do I need to replace the entire harmonic balancer?
I have a spare slant in my garage that I can rob parts from.
'78 Volare 225
'67 Charger 318
PostPosted: Tue Nov 08, 2011 4:22 pm
My 2¢: Noisy power steering pump?
Olaf
Aspenized
PostPosted: Tue Nov 08, 2011 5:23 pm
The AC pulley bolts to the back of the damper and the power steering pulley to the front. The damper ring is bonded to the hub and if it's loose then it much be replaced/rebuilt. There have been recent discussions on dampers if you don't have a good one around.
 Post subject: x2
PostPosted: Tue Nov 08, 2011 6:15 pm
Yep...or if taking the gamble take the one off your spare slant but it may fail in short time due to age and wear as well...
PostPosted: Tue Nov 08, 2011 8:18 pm
So does that whole thing just unbolt?
Thanks for the replies!
'78 Volare 225
'67 Charger 318
PostPosted: Tue Nov 08, 2011 9:49 pm
There are three bolts on the front of the damper. These remove your power steering drive pulley. Then depending on the damper you have (after you get it off the car) the rear pulley may unbolt also. The damper on my truck had both the rear sheaves bonded to the damper.
Look on ebay for nice quality dampers made in the land of Oz.
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Tue Nov 08, 2011 10:40 pm
The damper is pressed onto the crank and requires a puller to remove. The sheet metal pulleys bolt to the damper hub.
PostPosted: Wed Nov 09, 2011 6:26 am
Thanks again for the replies fellas!
What's strange to me is that it doesn't make this sound all the time. Last night, it started making this noise about a minute after I drove off from work, and it stopped after the slant had warmed up. This morning, as I drove my youngest son to daycare, it did not do it at all.
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 13, 2011 3:18 pm
Okay, so I need to use a puller to get it off. When I install the new/unbroken one, do I need to use an installer? Or will a rubber mallet suffice?
I've never done this on a slant before. :shock:
Thanks in advance fellas!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 13, 2011 3:40 pm
All you need is the bolt that goes in the crank snout. Slider the damper on as far as you can by hand, then use the bolt to press it the rest of the way on. This only works if there is no pulley bolted to the front of the damper.
PostPosted: Sun Nov 13, 2011 4:19 pm
Thanks Reed!
However, I don't seem to have one of these bolts. Can you suggest where I might find one? Or what size I need?
Thanks!!!
'78 Volare 225
'67 Charger 318
PostPosted: Sun Nov 13, 2011 4:33 pm
Find a junked Mopar smallblock at the boneyard. They usually have them. That is where I get mine. People have posted the size and thread pitch in numerous other posts on the board if you want to get a brand new one.
I.E.
3/4 - 16 UNF
If you want one, go with 3/4-16 x 1.5" and a big washer.
F.Y.I. the bolt head size is 1 1/4 inches.
PostPosted: Sun Nov 13, 2011 5:47 pm
Okay, thanks again!!!
:D
'78 Volare 225
'67 Charger 318
PostPosted: Mon Nov 14, 2011 4:23 am
I have found, that most of the time, the small/big block bolt is not long enough to get enough threads started to pull the damper on. Easiest way, is to, either get a longer bolt and some washers form a nut/bolt store, or get an "installer from a part store tool loaner program. All depends which is more convient.
PostPosted: Mon Nov 14, 2011 6:08 am
A simpler tact: Have you tried removing the belts when the noise begins? Seems like that could eliminate (or single out) a noisy alternator or PS pump pretty quickly.
When mine made a noise like you described it turned out to be the alternator.
- Mac
