It is currently Fri Nov 27, 2026 11:44 pm
PostPosted: Fri Nov 11, 2011 11:55 am
I am rebuilding a 1979 slant six 904. All was going well until I attempted to reassemble the front clutch pack after completely disassembling it to replace the clutches and seals. The problem I am having in the front piston outer seal is not sliding down into its bore like it should. I thought I had it but upon reassembly the outermost clutch pressure plate sits far above the groove for the wavy snap ring.
Is there a trick to getting the piston to sit in its bore with a new seal on it? I installed the new seal the same way the old one came off with the outer leg of the "L" pointing toward the bottom of the piston bore. Is that right? There is a chamfer around the top of the piston bore that looks like it should let the new seal gently compress a bit and slide int place, but it just isn't happening. The piston won't bottom out even with the clutch spring in place.
Help! :?
PostPosted: Fri Nov 11, 2011 1:07 pm
The lip probably got pinched. I take a paper clip and use the rounded end to work the lip down into the housing, while keeping gentil pressure on the piston. Be carefull not to knick the lip of the seal.
PostPosted: Fri Nov 11, 2011 1:18 pm
6 Pack Dart
I use a chunk of mylar sheet (a little smaller than the circumference of the hole) to guide the seal into place. After it is in place pull the sheet out (lube both sides of the sheet first).
Richard
PostPosted: Fri Nov 11, 2011 2:51 pm
Thanks for the tips. I got it in with a hammer and a nut driver. :twisted:
PostPosted: Fri Nov 11, 2011 3:20 pm
6 Pack Dart
Reed don't forget to air check the cluches!
Richard
PostPosted: Fri Nov 11, 2011 3:47 pm
Will do. This is my first ever total transmission rebuild and I am treating it mostly as a learning expedience. I doubt this transmission will see any use other than as a holder for the ring gear to start the engine on a test stand.
As soon as I get this 1979 transmission all back together, I am going to tear down a 1973 slant 904 and upgrade it with the guts from a rebuilt 1968 318 904. The modified 73 904 will be going into my brother's Duster.
PostPosted: Mon Nov 14, 2011 12:07 pm
Wrap a big rubber band around the piston to compress the seal lip, then throw the piston in the freezer for a couple of hours. When you are ready to assemble, remove the rubber band, smear a little tranny jelly on it, and it should drop right in.
Been working for me for years on all kinds of trannys.
PostPosted: Mon Nov 14, 2011 12:11 pm
Thanks, I'll give that a try on my next trans rebuild.
