It is currently Wed Oct 14, 2026 2:26 pm
PostPosted: Mon Sep 26, 2011 6:30 pm
Hi all
Im having trouble finding the correct setup for my RHD Dodge Dart Slant Six.
Can someone please take a closeup picture and measure the Rod pictured in this diagram below, item number 14-11-9, so I can fabricate something that will work on my car.
If your LHD Slant six is equipped with A/C, yours should be using throttle cable and very similar to the setup ive shown above.
Thanks again.
Syed
Malaysia
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Mon Sep 26, 2011 8:23 pm
For clarification (since I'm the one sent 'im the diagram):
1. There are two rods with ref number 14-11-9 in the diagram. The one he needs measured is the left one, running from carburetor throttle lever down to the bellcrank on the linkage bracket. Roughly 6 inches long, but a precise measurement is needed.
2. This rod, part number 2268 356, was used from 1966-'68 in all Left-hand drive slant-6 automatic B- and C-body cars, all '67-'68 LHD slant-6 automatic A-body cars, and all '66 LHD slant-6 A-body cars with factory A/C. An almost identical rod was used on '62-'65 slant-6 automatic B- and C-bodies.
3. The '69-up setup is similar, but not the same; the rod in question on these later cars is slotted at its lower end.
PostPosted: Mon Sep 26, 2011 9:03 pm
Thanks Dan.
Also, if anyone has a spare said ROD would be even better! :)
PostPosted: Tue Sep 27, 2011 12:58 am
Also, the pin itself is a standard hardware item called a "clevis pin". All it needs to be the right diameter and the right length.
PostPosted: Tue Sep 27, 2011 7:06 pm
Thanks Dan, sent you a PM (again) :)
PostPosted: Sat Nov 12, 2011 3:56 am
Just to update you, Dan.
Received my long throttle cable from Australia today :)
PostPosted: Sat Nov 12, 2011 9:01 am
Hoorah. Which vendor did you wind up buying from?
PostPosted: Sat Nov 12, 2011 8:00 pm
www.pentastarparts.com.au
They've been pretty helpful this side of the pond :)
PostPosted: Wed Nov 30, 2011 9:28 am
I just bought a 2bbl manifold and carb for my /. Is this the cable needed to make it work? I thought I could use my standard 'rod' throttle that came with the 1bbl. Any suggestions?
This? http://www.pentastarparts.com.au/sunsho ... ail&p=1178
Its a 3 speed manual so dont need to worry about kickdown linkage.. Thanks!! :roll:
PostPosted: Wed Nov 30, 2011 9:33 am
The object of this thread is a foreign '66 Dart with right-hand drive. Totally different situation than your car. Please start a new thread to ask about your 2bbl conversion.
