It is currently Wed May 13, 2026 12:28 am
PostPosted: Fri Nov 11, 2011 11:52 am
Well I ran my car out of gas :oops: And now it runs like crap, it chugs like a lawnmower. I replaced the fuel filter and bought a second one, should I clean the plugs too, because I didn't realize it was out of gas and proceeded to crank it over again and again. So I'm assuming the plugs have something to do with it too. Thanks in advance for any ideas on how to get it running smooth again.
Annabelle: 1970 Dodge Dart Hardtop
1991 Nissan 240sx (sileighty) Lots of mods
1974 Dodge Dart *Wrecked*
PostPosted: Fri Nov 11, 2011 12:44 pm
You're going to have to pull the carburetor apart and clean it very carefully.
PostPosted: Fri Nov 11, 2011 1:28 pm
Yep,you might even have some gunk/blockage in the lines running from the tank and the sending unit itself. Never let it get below 1/4 tank,thats where all the "trash" sits.
PostPosted: Fri Nov 11, 2011 2:03 pm
before you pull the entire carb apart try this.......disconnect the fuel line and remove the needle valve and seat. clean it out and make sure there is no debris in it. i have had stuff keep the needle from seating and what happens is the carb floods, making it run crappy
71 valiant 225, 904, 7 1/4
69 W200 power wagon 318, np435, np205, d44 front, d60 rear
PostPosted: Fri Nov 11, 2011 2:13 pm
I use to always put a quarter tank in my Scamp. I would change the filter quite a bit and the carb still got messed up.
'73 Scamp (the girlfriend): 225ci super/6 2BBL conversion (Almost done!)
'90 Subaru, wagon (the wife): H4-cyl 2.2L
1977 Mercedes-Benz 300D, 5cyl diesel(For sale!)
PostPosted: Fri Nov 11, 2011 3:24 pm
A lot of gas filters don't catch the fine stuff unless you get one that goes below 10 microns. Mine goes to the 2 micron level and it sure is nice......no more carb rebuilds or quick tear downs. The bowls used to collect very fine sediment or something would stop the needle and seat from sealing, but no longer.....
I will never go back to a common standard in-line filter. It would have to be a very high quality filter. Maybe SL6 Dan knows of some.....
PostPosted: Fri Nov 11, 2011 4:10 pm
I'm really not sure why but I have a fram plastic filter on my Scamp. I could have sworn there was a link for a higher quality filter in the sticky thread?
PostPosted: Fri Nov 11, 2011 4:29 pm
Thanks for the feed back, I will take apart the needle and seat, and take off the fuel bowl and clean everything really well
PostPosted: Fri Nov 11, 2011 5:14 pm
Before cleaning the carb and installing a new filter, to reduce chances of furture problems, drop the tank and clean it out. After dropping the tank and removing the pick up/sending unit, I just clean the tank out with some a pressure washer after spraying the inside with oven cleaner and letting it sit an hour. Some people take it to a radiator or machine shop and have it boiled out in a caustic tank. It also a good time to change the fuel line flex sections at the tank and fuel pump with new rubber line.
Slant Cecil
PostPosted: Sat Nov 12, 2011 10:57 pm
I got this resolved. I cleaned the needle and seat and then checked all the spark plugs and found #4 was completely gas fouled so after cleaning it up my car ran like it used to.
PostPosted: Sun Nov 13, 2011 6:14 am
I thought the fuel pickup was fixed in the tank? And thus always pulling from the bottom of the tank.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 16 guests
