It is currently Fri Jan 02, 2026 12:16 am
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Sun Nov 13, 2011 7:03 pm
Danarchy:
The car also had a grill cover that worked like a horizontal roman shade from a pull handle under the dash
Most of the high end cars of the 20’s & 30’s had louvers thermostatically controlled to adjust air flow to radiator, rather than an in head thermostat used on more modern cars.
PostPosted: Mon Nov 14, 2011 7:40 pm
NE. uses aluminum license plates with no embossing. Would one of those work good for this?
Sure. Perfect.
Sam
PostPosted: Mon Nov 14, 2011 11:23 pm
The only reason I can see for rounding the corners is to reduce the potential for injury. From experience, I can also suggest putting a file to edges created by tin snips. The little buggers can be hard on hands.
You can't fix stupid. - Ron White
