It is currently Wed Dec 31, 2025 2:18 am
 Post subject: Winter is coming....
PostPosted: Fri Nov 18, 2011 9:15 am
Car Model: Road Runner
And that means its time to do stupid stuff in the garage. I've got a really fun idea of a slant six "goal" for 2012. Been bench racing this for some time now, what do you guys think of this?
Intent would be 3 smallish 1bbls on a 198 (preferred) or a 225. Engine will need to be near WOT for 5 or so miles....(hint hint)
PostPosted: Fri Nov 18, 2011 1:40 pm
Sounds like fun, but I'd probably spend my time on EFI or a turbo setup. Runner lengths should be somewhere around 12-15" for WOT at 5000 RPM. That's just a guess and would need to calculate...
I get your hint. Wouldn't it be cool to have TWO Slant 6 cars at that Spectre 341 deal??
PostPosted: Fri Nov 18, 2011 1:51 pm
Looks like a neat set up! Definitely eye candy!
We missed our opportunity at Maxton Lou... :(
PostPosted: Fri Nov 18, 2011 2:43 pm
6 Pack Dart
Simplify your set up, one carb for 1&2 one for 3&4 one for 5&6.
I agree on 15" runner length.
Richard
PostPosted: Fri Nov 18, 2011 4:34 pm
I would dread a Slant without a blower for 341. I would warn that you need at least a 9 to 1 Lbs/hp rating (corrected) if you really want to give the hill a go. My plan for this car/motor will be a lot flatter....and saltier.....yeah.....
Richard
My only concern with that was for even intake pulses and smoother operation. Am I wrong on this?
PostPosted: Fri Nov 18, 2011 4:47 pm
6 Pack Dart
With either set up you go from one carb to another, no such thing as even pulses.
Richard
PostPosted: Fri Nov 18, 2011 5:39 pm
Here's the way I see it. With my plumbing the carbs would see this...
Carb 1:pull........pull........pull........
Carb 2:....pull........pull........pull....
Carb 3:........pull........pull........pull
Where yours would be:
Carb 1:pull............pull....pull............
Carb 2:........pull........pull........pull....
Carb 3:....pull....pull............pull........
see what I mean about funky signals?
PostPosted: Fri Nov 18, 2011 5:40 pm
Huh, I looked it up, and the firing order is 1 5 3 6 2 4. By the looks of it, each carb "sees" a pulse, then dead for one crank revolution, then it sees a pulse on the other runner. I guess if the runners are long enough then it'll iron out.
Interesting idea.
PostPosted: Fri Nov 18, 2011 5:58 pm
6 Pack Dart
"Huh, I looked it up, and the firing order is 1 5 3 6 2 4. By the looks of it, each carb "sees" a pulse, then dead for one crank revolution, then it sees a pulse on the other runner. I guess if the runners are long enough then it'll iron out"
Correct!
Richard
Looks like a BMW intake...........
Each carb would need to be sized as if it was feeding all 6 cylinders.
PostPosted: Fri Nov 18, 2011 6:17 pm
Poser
Looks like something the Ramchargers might have come up with. Don't have a clue if it would work but it sure looks like fun!
PostPosted: Fri Nov 18, 2011 7:25 pm
See here.
PostPosted: Fri Nov 18, 2011 7:28 pm
Car Model: '23 T-bucket
Care to clarify, EMS? From the OP's drawing, it appears that there is no interconnection between carb plenums or runners. My thinking is that the carbs would be sized for only the two cylinders each, and tuned for a two cylinder engine of 75 c.i.
The hard part would be tuning the carbs for equal vacuum across the board, as it would act as if it's three seperate engines, but running on a common crankshaft.
Roger
PostPosted: Fri Nov 18, 2011 8:08 pm
See here.
What are you suggesting Dan?
PostPosted: Fri Nov 18, 2011 8:14 pm
A carb sized for only 2 cylinders wouldn't flow enough air.
Because the flow is pulsed, you need to take into consideration peak flow.
The pic shows the airflow requirements for each cylinder(about 240 degrees for every 720 degrees (2 crank rotations)), with max flow at intake valve fully open, less flow proportional to valve opening.
The peak flow (intake valve fully open) is just about the same as the average flow for all 6 cylinders.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 19 guests
