It is currently Wed May 20, 2026 2:41 am
PostPosted: Wed Nov 23, 2011 6:56 am
Hi
Installed the Aircleaner today and adjusted the timing. The 7/16" bolt beside the distributor is fully tighten but I could still turn the dist by hand! Am I missing something? Is there another bolt holding the dist in place? Thanks.
Syed
Cars: 1966 Dodge Dart 270 Convertible,
1990 Alfa 164 Twin Spark
1980 BMW 735i 5-speed
http://www.weddingcar4u.blogspot.com/
PostPosted: Wed Nov 23, 2011 7:06 am
Take a look at the underside of the distributor and the claw arrangement, to see if the clamp is right.
HERE's a photo of one variation. Note the bolt going up into the distributor. That gives two points of adjustment.
PostPosted: Sat Nov 26, 2011 5:40 am
Sorted... Thanks.
PostPosted: Sat Nov 26, 2011 6:01 am
If you are clever,and lucky, you can get a 7/16" box end wrench on that bottom bolt without taking our the distributor.
Sam
PostPosted: Sat Nov 26, 2011 6:40 am
I've never managed to achieve that - I'll have to get some dead skinny spann - I mean wrenches :lol: .
I do have a steering column in the way though.
1960 Plymouth Belvedere 4 door sedan
Stock 60 225
Push button 3 speed Torqueflite
Right Hooker
PostPosted: Sat Nov 26, 2011 6:52 am
On the backward American versions, I think you must remove the oil filter to do this. It kind of fits in nicely with an oil change. I change my filter more often than I change oil though.
Sam
PostPosted: Sat Nov 26, 2011 8:51 am
See here
Users browsing this forum: Google [Bot] and 26 guests
