It is currently Sat Jun 20, 2026 7:20 pm
 Post subject: Drum to Disc
PostPosted: Sun Nov 13, 2011 1:42 pm
what A body or car can I take spindles off to work on my 72 duster for a swap
1972 Plymouth Duster 225 Super Six Slant
PostPosted: Sun Nov 13, 2011 1:56 pm
Use the search function on this site and search for "Disc brake swap"
PostPosted: Sun Nov 13, 2011 5:39 pm
here's a bit of off site information.
http://mopedia.org/A-body_disc_brake_conversion
1964 Dart GT
PostPosted: Tue Nov 22, 2011 6:15 pm
Disc brakes from almost any RWD Mopar smaller than a C body can be retrofitted to a '72 A body.
The real trick is figuring out which one of the many choices is actually the best.
If it was me I'd run tall knuckles, 11.75 rotors and rear hung slider calipers with custom hoses. But that is just me, others disagree with my choices.
PostPosted: Wed Nov 23, 2011 1:06 pm
I'm running a short knuckle, 11.75" rotor, rear hung slider setup, and Aspen / Volare hoses fit it just fine. I suspect they'd also fit the tall knuckle setup. You just have to remove that metal tab on them.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: How about keeping SBP?
PostPosted: Tue Nov 29, 2011 11:11 am
Car Model: 1962 Dodge Lancer GT Black/Red
I am entertaining options of staying with Small Bolt Pattern front and rear to save on weight while improving stopping function. Any replies / ideas?
PostPosted: Wed Nov 30, 2011 12:50 pm
SCAREBIRD is one option for the front. It uses newer calipers and rotors.
PostPosted: Thu Dec 01, 2011 4:01 am
On a scarebird installation into two different 65 Darts I found that in each case the stock 4.5 inch wide wheels severely rubbed on the calipers....even grinding didn't help...
Pictures of the mods made to the scarebird install to make stock wheels work are available.
Scarebird recommends aftermarket wheels.
Search the slant six site for more discussion on this install
PostPosted: Thu Dec 01, 2011 8:35 am
seems a pity cause I like the look of steelies with dog dish wheel covers like the factory got rods of the sixties. 15" steel wheels with SBP seen to be quite rare. Correct me if I'm wrong, but as I recall that the 8 1/4 rear and '73 and up disc brake upgrade will add 150 lbs to the weight of the car. Albeit it is unsprung weight.
PostPosted: Thu Dec 01, 2011 9:05 am
Be aware that if you use the setup from a '73-76 A-body, your front track will be wider on each side by about 7/8". You can use wheels with more backspacing to compensate, assuming they're available.
PostPosted: Thu Dec 01, 2011 9:49 am
I can provide you with how it's possible to modify the Scarebird kit to work for the fronts...I recorded photos of the modifications used on both my 65 & my daughter's 65 Dart.
My thinking was identical to yours in terms of keeping things lightweight for good gas mileage and the appearance; however the Scarebird modifications require a visit to the machine shop, etc.
If your good with that send me a PM & I'll send you photos & machining instructions.
ps: as far as the rears go you'll find the stock brakes will drag the rear tires before the fronts will.....I even tried studs and still the lightweight rear begs the question as to what the purpose of discs would be back there?
PostPosted: Thu Dec 01, 2011 10:19 am
Right Don Pal. 9" rear drums should be adequate on a street driven 6 while 70% of the stopping force is on the front brakes. Thank you for sharing. :)
