It is currently Sat May 09, 2026 6:33 pm
 Post subject: start
PostPosted: Thu Dec 01, 2011 10:53 pm
well lets start of with my motor cranks, there is gas, and seems like fire , no fire over. it overheated before and since will not fire over yet there are no oil leaks gaskets are good rockers lifters and all in tact. what might be the problem. thanks for all input :?
PostPosted: Thu Dec 01, 2011 11:02 pm
Site Admin
Ballast resistor
Compression
Head Gasket
Valves
Timing
Points, condensor, plugs, coil.
Wiring, connections, switches, and so forth. Pretty much hands on to troubleshoot.
Do you have a Factory Service manual?
Test the ballast resistor first. A new one is relatively inexpensive, and is a must have spare in your glove box.
2¢
CJ
 Post subject: Re: start
PostPosted: Thu Dec 01, 2011 11:28 pm
and seems like fire
Seems like? Either there is spark or isn't... pull a plug and leave it attached to the wire. Hold the plug against the block or any other convenient ground while someone cranks (or use a remote starter switch) and watch for spark to jump across the gap. You could use the coil wire to eliminate the cap/rotor.
PostPosted: Fri Dec 02, 2011 6:49 am
First place I would look:
If your engine fires & tries to run while starter is engaged, but as soon as key is released no run, suspect a bad ballast resistor. It can be tested with ohm meter disconnect any wires connected to resistor first. If test shows high resistance, it is no good, if test shows roughly 0.5 to 1 ohm it is good.
Users browsing this forum: Bing [Bot] and 18 guests
