It is currently Sun May 03, 2026 7:15 pm
 Post subject: i need rockers
PostPosted: Fri Dec 02, 2011 2:18 pm
if anyone has a good bitchen set of rockers, where everything still fits tight, and is willing to sell them, i need a set. if not, is it even worth looking in the junkyard and pulling them all off untill i find a good set, or are they usually all bad. i tried using the vice trick to pinch them tight for the adjuster, but i can either not pinch it enough, or it cracks the rocker... i feel this tecniuqe is $#!+. i should have just left the jam nuts on there :\
PostPosted: Fri Dec 02, 2011 8:07 pm
My local parts house said they had a machine shop that would sell me a rebuilt rocker arm assembly (includes all rockers, locknuts, etc) for around 75 bucks.
Try Oregon Camshaft as well, as I seem to recall they had assemblies too.
Used ones are ok, if they're not destroyed (they tend to be good or destroyed, not much in between). I now have many locknuts on mine and probably will eventually find all the adjusters locknutted...
'81 W150 on Propane... Oversize valves, Oregon Camshaft cam, 10:5 static CR, Distributorless ignition, megajolt timing controller, PowerTrax lockers.
PostPosted: Fri Dec 02, 2011 8:55 pm
I just wanted mine to fit tight, so I could adjust them all while car is running, then shut car off, and lock nut them all
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 1 guest
