It is currently Fri Oct 09, 2026 6:59 pm
Post new topic  Reply to topic  [ 27 posts ]  Go to page Previous 1 2
PostPosted: Wed Dec 07, 2011 9:53 pm
I pulled my engine and tranny out the top, together. I then did a rebuild on the engine, and also completely rebuilt the front suspension. When I put them back in, I mounted the engine and tranny into the K-member, raised the car and dropped it down on the whole assembly. It went very smoothly, and was almost a one-man job. If you're not re-doing the front end at the same time, it's a bit more work.
 Post subject: Workshop. Yes!
PostPosted: Wed Dec 07, 2011 9:56 pm
And that, my friend, is a workshop that few of us have, but all of us dream of.
63 Plymouth Valiant V200 Convertible.
225, HEI, Super Six with 38/38 Weber, Electric Fans, Scarebird discs, FirmFeel front swaybar.
PostPosted: Wed Dec 07, 2011 10:17 pm
How i lifted mine out and in,a bit of 50 mil angle bolted to the centre hole on top of the head.Image
Another AP5 valiant still going strong.
PostPosted: Wed Dec 07, 2011 10:27 pm
Cheater.
PostPosted: Thu Dec 08, 2011 10:37 am
COOL Oil Filter location!
and yes raising the whole car up and lowering it on the engine is Cheating(Fab64)!
1964 Dart GT
PostPosted: Thu Dec 08, 2011 10:12 pm
Yeah thats standard on all ozzie slants.
PostPosted: Fri Dec 09, 2011 6:31 am
Damn'righthand drive :lol: , still cool!
1964 Dart GT
PostPosted: Fri Dec 16, 2011 8:16 pm
Thanks for all the suggestions. Turned out to need more angle, a load leveler and.....an upside down motor mount. :oops:
Shes in and hooked up. However I have reason to suspect while doing my timing I rushed through it a bit and forgot to set the motor to TDC #1 before lining up the dots. I believe ill aquire a degree wheel as well.
Noticed some coolant coming out of either the head gasket below the 3rd bolt in (bottom) or its leaking through the stud hole as they were only threaded in hand tight...
Either way thanks for the help and hopefully she will live soon!
PostPosted: Fri Dec 16, 2011 10:27 pm
6 Pack Dart
Bet the upside down motor mount was on the distributer side. :lol: :lol:
Richard
PostPosted: Tue Dec 20, 2011 10:20 pm
Haha it sure was.
Motor mount looked right... with the engine OUT of the car...
Unfortunately it took a whole day of :evil: to see it was on wrong.
Thanks for all the help everyone!
PostPosted: Wed Dec 21, 2011 9:13 am
Haha it sure was.
Hey, don't feel bad. I did the same thing - very easy to do if you're not familiar with it. Luckily, I noticed it outside of the car. Glad you got it sorted out. :)
PostPosted: Wed Dec 21, 2011 5:55 pm
I also believe its much easier to do the motor and trans together, less chance of messing something up by not aligning them correctly
87 Dodge B150 Slant 6 Auto
Users browsing this forum: Google [Bot], RumDungeon and 15 guests
