It is currently Tue Jun 16, 2026 8:00 pm
PostPosted: Sun Dec 18, 2011 6:42 pm
Click on the link for pics. Hope you enjoy!
http://www.forabodiesonly.com/mopar/vbp ... iew&g=5727
PostPosted: Mon Dec 19, 2011 7:32 am
Nice!
PostPosted: Mon Dec 19, 2011 5:48 pm
Hi Sandy in BC
I am relatively new to this forum so I am not aware of the destruction of a rare , vintage automobile. Can you fill me in so that I can be better prepared to intelligently respond.
Ken
PostPosted: Mon Dec 19, 2011 6:10 pm
Toyota Cressida seats in a 65 Valiant! :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :lol: :lol: :lol: :lol: :lol: :lol: :lol: :D
1964 Dart GT
PostPosted: Mon Dec 19, 2011 6:38 pm
They are not Toyota seats! I wouldn't do that. Heaven forbid! The seats are from an 86 Chrysler. I put them in 25 years ago. The donor car was totalled with only 3500 miles on it so the seats were in beautiful condition and I could not resist buying them.
Keep the faith,
Ken
PostPosted: Mon Dec 19, 2011 6:43 pm
No not your seats, Sandy BC's. click the link in the signature line.
http://www.arrowtipi.com/My%20Webs/index%20Valiant.htm
:lol:
1964 Dart GT
PostPosted: Mon Dec 19, 2011 6:51 pm
Oh ye of little faith.........
PostPosted: Mon Dec 19, 2011 6:58 pm
OK Ken....we all know BC is bigger than California....what part are you from?
West Kootenays here.
PostPosted: Mon Dec 19, 2011 7:04 pm
I'm in Abbotsford. Um ah um, nice looking seats eh
Ken
PostPosted: Tue Dec 20, 2011 6:26 am
Looks great. Keep the Slanted boosted faith...
PostPosted: Tue Dec 20, 2011 10:43 am
I'm not downin' the Toyota seats, they are much nicer than my stock buckets.
1964 Dart GT
PostPosted: Tue Dec 20, 2011 10:56 am
Engine specs? :D
PostPosted: Tue Dec 20, 2011 12:39 pm
Engine specs...OK here goes:
68 block and crank bored .025" over, power honed with torque plate, ARP studs on mains and head, jackets half filled with block rock prior to machining, decked and align honed etc, wiseco forged pistons, K1 rods 7.00", high volume pump, 7 quart baffled pan, windage tray, oil cooler, Comp Cams solid lifter, 215dur @ .050, 435 lift, 110 lobe sep(jury still out on if this cam will stay)
70 head ported and flow tested 152 cfm exh, 192 cfm int, 1.70 int, 1.44 exh stainless valves , 64cc chambers-all matched,stock rockers and pushrods.
Offenhauser 4bbl manifold, ported to accompany head, stock CI exhaust manifold modified to accept turbo, Impco 425 Propane mixer, 2 model e vaporizers modified for pressure, adjustable pressure controlled wastegate c/w 2 1/4 bypass pipe, 50mm bov, 4" exhaust from turbo into 2 -21/2" mufflers and tailpipes. Large water to air intercooler rated at 0.1 pressure drop @ 750 cfm
Full instrumentation for boost, exh gas temp, int air temp, oil temp, trans temp and wideband air/fuel, all with data logging.
Trans is modified TF904, 2.74 low gear set, 4 clutch drum front and rear, raybestos plates, kolene steels, billet servos, transgo kit, deep pan, 9 1/2 converter 3200 stall and large cooler.
chassis dyno testing will be done in spring. I will keep you informed.
Hope I haven't bored you with details.
Ken
PostPosted: Tue Dec 20, 2011 3:55 pm
Sounds very cool. What turbo are you using? Any idea what kinf of power it makes?
PostPosted: Tue Dec 20, 2011 4:36 pm
I am using a Schweitzer turbo with 68mm wheel which will produce 47.5 lbs/min at 2.4 pressure ratio which should equal 406 HP corrected for temp rise and fuel type. I plan on limiting the p/r to 2.2 which will drop the hp to approx. 380 @ 5500 RPM. I am still playing with the fuel delivery, so I have not exceeded 1.8 P/R which makes for a very fun ride. The tires will not hook up even with the current pressure.
More later,
Ken
