It is currently Fri Apr 24, 2026 8:11 am
PostPosted: Sun Sep 28, 2003 6:13 pm
Well, I have commited myself,(maybe I should be commited). I sent money off to Bigblockdart.com for upper control arms, and solid, adjustable front struts. I also orderd a pair of .890 torsion bars. I know this is a lot of noise from a guy who hasn't said much lately, but the hanling section of slantsix.org is very thought provoking, and sort of cutting new ground in many ways. I am really hoping Donna,(my slant's name) comes out of this carving corners like a sports car. Thanks again for the help. I coudn't have made up my mind without your help. I'll keep you posted as I get the stuff installed.
PostPosted: Sun Sep 28, 2003 8:05 pm
Put a cop box or a firm feel type steering gear in, or all that high tech handling stuff is gonna be lost in your mush-a-matic stock gear (It is a stock one you have, yes?).
"DW"
If it ain't broke, fix it!
PostPosted: Mon Sep 29, 2003 2:17 pm
Dennis, I might eventaully do that. It will be interesting to see how it feels with a stock box,(I assume it is), and good front end parts. I might even go manual steering, although I am going for a high caster number here, and manual steering can feel pretty tough with 6* caster. We will see. The long range plan is for a turbo, and I certainly want to get the steering thing settled before I get turbo plumbing in.
 Post subject: ?
PostPosted: Mon Sep 29, 2003 7:53 pm
Two things I'd suggest looking at:
1) Make really sure the steering box is still torqued properly to the K member. Also make sure the steering box bracket is still firmly attached to the K member.
2) Some times I've found that when you stiffen the rear springs it tends to make the car want to oversteer, which is exacerbated by weak frt torsion bars.
'66 Cuda 225/4spd
'64 Dart GT 340/4spd
PostPosted: Tue Sep 30, 2003 6:52 am
AHAH! Bud - great idea on the rear spring stiffening. I had forgotten about this on Vader's car. This is a likely candidate, since I know Vader did stiffen his rear springs and uses stock T-bars.
I bet the 0.890" T-bars will help.
PostPosted: Wed Oct 01, 2003 5:46 am
Good tips on both accounts. Putting a wrench on the stearing box bolts should be easy. The bolts are those silly bolts with a reduced head size, so gettin them torqued tight is difficult. Thanks again.
 Post subject: ?
PostPosted: Thu Oct 02, 2003 6:35 pm
Don't forget LocTite. My box came loose on my '66 Cuda and broke the Kmember attaching bracket. I had to weld the begeezus out of it to beef it up.
'66 Cuda 225/4spd
