It is currently Wed Oct 14, 2026 2:09 am
PostPosted: Wed Dec 21, 2011 9:14 pm
This is my new carb. Any ideas?
PostPosted: Tue Jan 03, 2012 1:55 pm
*bump* im having to take out the intake/exhaust manifold to head studs as they had a small leak..
Does anyone have the length of throttle cable it would be for the conversion to supersix from the 1bbl shaft style?
Im looking at getting a throttle bracket and cable... http://www.ebay.com/itm/67-70-Mopar-Big ... 583wt_1398
Thanks in advance!!
ps. Ive got the kickdown linkage I believe for this. I dont need it being that its an A903. Any ideas on making some sort of adaptor out of it? :wink:
PostPosted: Tue Jan 03, 2012 2:21 pm
The correct factory throttle linkage assembly for a 65 A-Body, when converting to the Super Six 2 bbl set-up, would come from a 64-66 A-Body w/ a 273 V - 8 or a 65-66 SL6 A-Body w/ factory AC. ( the AC SL6 cable will be too long but can be swapped)
These set-ups use a different gas peddle and a special bracket that bolts to the firewall... and a cable to replace the rod.
The bad news... no aftermarket support for this stuff so these parts are hard to find these days.
Most people get the later "free-hanging peddle" throttle linkage out of any 67 and up vehicle, then drill some new holes to mount it to the firewall.
PostPosted: Wed Feb 08, 2012 4:21 pm
Alright well back from the dead!
Thanks for that advice. Clears up alot. Would this pedal assembly then suit the task at hand? http://www.ebay.com/itm/250993278289?ss ... 500wt_1181
Found this one and it can be had at a very reasonable cost.. http://www.ebay.com/itm/140696535157?it ... 1000wt_107
You guys have been such a great help. My girlfriend just had our first son 2 weeks ago so im very keen on getting this project done already.. Just dont have the time anymore to research in depth..
Also, going through my garage again I noticed this.. Image
Any ideas where it came from? :oops:
Users browsing this forum: Bing [Bot] and 9 guests
