It is currently Tue Jun 09, 2026 9:33 am
PostPosted: Tue Dec 27, 2011 3:43 pm
Can someone tell me the difference in ball joints from 61-62 lower ball joint from the 63 on up ball joint? I have a pair of the early ball joints however they don't seem to be the same as the later ball joints.
PostPosted: Tue Dec 27, 2011 4:49 pm
'60-'61 vs. '62-'72 is the interchange grouping.
PostPosted: Tue Dec 27, 2011 6:21 pm
So what's the differance? Earlier are rebuildable. The two NOS ball joints I have don't appear the same as the later ball joints. The later joints are more of a interfearance fit while the earlier ball joints I have appear to be loose.
PostPosted: Sun Jan 01, 2012 8:12 pm
Do you have 61/62 lowers? I may need a set.
76 Dart
PostPosted: Mon Jan 02, 2012 6:07 am
60 & 61 lowers were similar to the uppers(threaded single unit), the replacement ball joint threaded into the arm, later 62 & up they made the lower ball joint assembly .
PostPosted: Mon Jan 02, 2012 8:24 am
Does that mean the uppers will fit?
76 Dart
PostPosted: Mon Jan 02, 2012 9:13 am
I have the 61 lowers
