It is currently Wed Jun 17, 2026 4:39 am
 Post subject: Eddy 500avs tuning chart
PostPosted: Thu Dec 29, 2011 4:22 pm
Just wanted to get an idea of where your settings are for those of you with a 500avs. Mine as of now is:
primary - base
secondary- base
needle- .068 x .052
spring- pink
acc pump- middle
My timing is 16* init + 16* mech with no vac on Mallory diz.
268 cam .016in .018ex
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Thu Dec 29, 2011 4:35 pm
I'm running an Edelbrock performer 1404, but they should be close if not the same Carb.
Primary - base
Secondaries - 1 step up
Needles - Base
Accelerator - outer hole
Orange springs
Timing 18* initial, 9* mechanical (I believe), not sure on the vacuum. Still have to map it. But she runs great!
PostPosted: Thu Dec 29, 2011 8:05 pm
My 500avs is setup like this:
primary: 3 steps richer
secondary: 2 steps richer
step up spring: 7.5hg
needles: base
accelerator pump: base
secondary valve spring: 3 full turns past no resistance
Ignition setup:
initial: 10* BTDC
total: 31.5* all in at 3000 rpms
vacuum advance hooked up and setup to eliminate surging.
The car runs great, best time of 8.31 in the 1/8 mile and 20mpg at 3000 rpms.
PostPosted: Thu Dec 29, 2011 8:17 pm
needles: base
Ignition setup:
initial: 10* BTDC
Sounds rich but I'm guessing elevation has something to do with that?
'72 4 dr Dart
'63 4 dr Dart
PostPosted: Sat Jan 07, 2012 4:35 pm
I'm having trouble tuning mine also my engine runs way too rich even with small jets, anyone got any ideas to overcome this problem?
PostPosted: Sat Jan 07, 2012 5:03 pm
Have you checked your float level?
PostPosted: Sun Jan 08, 2012 1:44 am
No I haven't I assumed it should be ok because it's a new carbi out of the box. What float setting do you guys run.
PostPosted: Sun Jan 08, 2012 4:09 pm
It should be 7/16 from the air horn gasket.
PostPosted: Sun Jan 08, 2012 4:18 pm
Don't "assume", in mine the floats weren't adjusted correctly and the inlet needles leaked. Either of which would cause a "rich" carburetor.
PostPosted: Sun Jan 08, 2012 5:16 pm
Same here.... Mine measured out at 7/16 without the airhorn gasket. Instructions with the Carb say to hold the gasket in place and use a 7/16 drill bit to gauge float height.
PostPosted: Sun Jan 08, 2012 7:57 pm
Cheers I'll check it out tonight and see what I've got.
PostPosted: Mon Jan 09, 2012 5:00 am
The float level was way out no where near 7/16. I set the floats and it seems to be a lot better. Bit more tuning and she should be running a bit better. Thanks fellas.
Users browsing this forum: Bing [Bot], Google [Bot] and 1 guest
