It is currently Thu May 14, 2026 12:58 pm
Post new topic  Reply to topic  [ 33 posts ]  Go to page 1 2 3 Next
PostPosted: Thu Dec 29, 2011 6:29 pm
I've been doing a lot of reading and research about oil filters. At first I thought it would be a great idea to use a Mopar oil filter on my 1971 Duster slant six. However, after reading much, I've determined that better filters can be had (and for less money) as long as I'm willing to forego the Mopar logo. It seems that Wix and Purolator both make affordable good quality filters. My question is this; since both of these brands offer two different size filters which will physically fit on my engine, is there a preferrable size??? short or tall??? They all offer anti-drain back capabilities. One more thing I would like to ask, has anyone ever seen the replaceable cartridge type oil filter used on a slant six? I found a Mopar part number 2532756 which is supposed to fit Chrysler six cylinder engines from the mid 60s thru 71. Would this filter be the correct equipment on a factory original restoration? I'm sure this has all been discussed here many times before but I am new and I apologize if I'm bringing up and old issue. Thank you for your time.
PostPosted: Thu Dec 29, 2011 7:16 pm
Car Model: '23 T-bucket
You make it sound as if you wish to keep your Duster as factory original as possible. I can see that, if you're going to enter it into a concours car show, where points are lost if you don't have the correct date-coded, belts, hoses, filters, etc.
From a practical standpoint, having an aftermarket filter on your original car isn't going to undermine it's possible collectability, as properly marked filters are still available for it.
I'd say go ahead and put a Wix filter on it, unless you ARE going to enter it into a concours show.
The tall or short filter was more of an application thing than an engine thing. If the tall one will actually fit into the somewhat tighter engine bay of your Duster, then use it.......it's got more filtering capacity.
The slant is recorded as being used in big trucks, all the way up to the D600, 2-ton, as well as many agricultural uses. Many of those were considered commercial use, and most likely got the cartridge-type filter. (An assumption on my part.)
I think the "newest" vehicle I ever had with a cartridge filter was a '64 Chevy Impala, 327 engine. The cartridge filters pretty much went away on passenger vehicles after that year.
Roger
PostPosted: Thu Dec 29, 2011 8:24 pm
Thanks Roger! I never realized how interesting oil and filtration could be. I started reading just to find out what size I needed and before you know it I was getting a great education on the quality and performance differences of the various brands. Thank you for taking the time to respond to my question and point me in the right direction.
Vincent
PostPosted: Thu Dec 29, 2011 9:29 pm
Stay away from Fram. Wix and Purolator are two solid easily-available choices. The super-premium Wix for your car is the 51806, which has a built-in standpipe to keep oil in the filter after engine shutdown so you get instant oil delivery on restart even after prolonged sitting. That one can be harder to find than the regular 51515, which is the same filter but without a standpipe built in. Drop the initial "5" from either of these if you're shopping at NAPA, where Wix filters are available as "NAPA Gold" filters.
The ultra-super-duper premium filter is a Fleetguard LF3487. Expensive and usually a hassle to find.
The replaceable-element oil filter was a fleet-only option. They're interesting, but that's about all they are.
PostPosted: Fri Dec 30, 2011 5:19 am
dont understand the fram bashing...have used fram for many years with never a problem
PostPosted: Fri Dec 30, 2011 5:28 am
Cut one open, and you will see.
PostPosted: Fri Dec 30, 2011 8:02 am
"don't understand the fram bashing...have used Fram for many years with never a problem"
http://minimopar.knizefamily.net/oilfilters/index.html
obliquely-inclined state of mind
PostPosted: Fri Dec 30, 2011 9:18 am
…and me, I don't understand why I should wear a seat belt. Have been driving for many years with never a crash.
Don't understand why I shouldn't smoke cigarettes, either. Many people smoke 'em for decades without getting disease.
Also, I've been shaking my left hand exactly four times at an angle of 88° over a green carpet every third Friday at 12:17 or 2:31 in the afternoon since I was nine years old, and I've never seen a purple crocodile so it must be working.
Do you begin to understand the problem with your logic?
PostPosted: Fri Dec 30, 2011 9:47 am
I don't get the carpet thing............
PostPosted: Fri Dec 30, 2011 10:24 am
hey dan does the carpet thing work for pink flying elephants too????? LOL
PostPosted: Fri Dec 30, 2011 10:38 am
I'll splain: The fact you've not (yet) experienced an engine failure due to poor oil filter quality doesn't mean it's a good idea to use inferior oil filters when good ones are available for about the same price, number one. Number two, how much life has been taken out of your engine by inferior oil filters? You don't know. You can't. A slant-6 is an exceedingly durable piece of machinery, but that doesn't make it smart to abuse it or use inferior parts.
PostPosted: Fri Dec 30, 2011 1:26 pm
I always strain my oil through green carpet. Never low-pile, always shag: more surface area to catch the ground up oil pump gear pieces...
PostPosted: Fri Dec 30, 2011 1:29 pm
i use astro turf, no strings or fibers to worry about, synthetic is the way to go ;-)
 Post subject: Lol...
PostPosted: Fri Dec 30, 2011 2:31 pm
I use the fram to catch the small partcles, then strain again through a coffee filter, add some Willamette Hops to the 10W-30 malt and fermet for about 3 months in the oil pan...drain and bottle, then leave in a cool dry place with even temperature for another year...
Sorry couldn't resist.
PostPosted: Fri Dec 30, 2011 2:46 pm
Actionbac carpets are the norm. They use a mix of SBR latex and calcium carbonate for adhesive and filler for the secondary backing attachment.
Some cheap stuff uses filtered dirt.
"DID YOU TELL'M ABOUT THE TWINKIE?"
Users browsing this forum: Google [Bot] and 38 guests
