It is currently Fri Oct 09, 2026 4:17 am
 Post subject: 61 Lancer
PostPosted: Mon Jan 02, 2012 7:49 pm
How to identify 170 vs 225?
76 Dart
PostPosted: Mon Jan 02, 2012 7:59 pm
Take a look at the engine ID number stamped on the flat surface facing skyward located at the top of the block, below the bottom of the head, inboard of the alternator bracket, and under the frontmost spark plug. You'll probably have to scrape away some grease to find the stamping.
 Post subject: Engine ID number
PostPosted: Tue Jan 03, 2012 9:45 am
The Engine ID number is R17 I014
Body tag
SO Number Bdy Trm Pnt
11034014 711 202 FF1
76 Dart
PostPosted: Tue Jan 03, 2012 10:04 am
You've got a 170 engine, and it's probably the original one to the car: the "R" indicates 1961 model year, and the "1017" means the engine was made on October 17, 1960. Your car was built on November 3, 1960 with a grey cloth/vinyl interior and "Spring Green" (kinda swimming pool green) paint, PPG paint code 42733.
Users browsing this forum: DuckDuckGo [Bot] and 20 guests
