It is currently Wed Jun 17, 2026 2:07 am
PostPosted: Wed Jan 04, 2012 1:55 pm
Hi folks,
I've just entered this forum, 'cause i bought an '67 Dodge A 100 Van in Ooctober Now I´m checking everything to get the thing running.
So here´s my question:
What´s that heat riser valve good for? I´ve read the article about the installation of the manifolds and how to customize the gasket between the two - but my valve is just gone! The mechanism´s there, but no flap.
To my understanding, the valve brings heat to the intake when the engine is still cold. When warming up, the valve closes and the heat from the exhaust is kept away from the intake, doesn´t it?
So driving without, doesn´t make sense! I´m thinking about closing the thing completly. What do You think?
Regards Achim
PostPosted: Wed Jan 04, 2012 2:47 pm
Hallo, Dingeldeins! Welcome on the board. I was in Darmstadt for a technical conference at TUD this past September, and will be again in September '13…perhaps I can see your van at that time! Image
The manifold heat control valve is there for a very good reason. It should be repaired and kept in proper working condition. Unless you have a race car, it is beneficial to driveability and fuel economy. See here.
Since you are getting the van into shape: Tune-up parts and technique suggestions in this thread. It will eventually need a valve adjustment. Carburetor operation and repair manuals and links to training movies and carb repair/modification threads are posted here for free download.
PostPosted: Wed Jan 04, 2012 3:51 pm
Wilkommen!
What Dan says is true. Come back often!
Auf wiedersehn,
Wes Moeller
'78 Volare 225
'67 Charger 318
PostPosted: Thu Jan 05, 2012 1:45 pm
Hello Dan, hello Wes!
I'm alallreadylad, i found this forum. Seems like You both know what your talking about and the links are very helpful and ininteresting
I think, I'll probably spend some evenings reading and writing around here.
Very inteinterestinghere, that You've been to Darmstadt, Dan! Maybe coming september the van's ready and running, so we can do some cruisin' thru the city. I'm looking forward to that.
So thanks for now
Achim
:lol:
´67 Dodge A 100
Love in it or leave in it!
PostPosted: Sat Jan 07, 2012 12:39 pm
Off topic here, but my wife and I went to Germany on our honeymoon, back in May 1998. We loved it! We landed in Frankfurt, but made our way through Munich, and spent a few days in Garmisch. From our room in Garmisch, we had a beautiful view of the Alps. When we got back to the states, my wife discovered that she was pregnant. Hmm, now how did that happen? :twisted:
Later,
'78 Volare 225
'67 Charger 318
 Post subject: It's...
PostPosted: Sat Jan 07, 2012 1:43 pm
The notorious Bavarian Breakfast...Krystallweizen and Weisswurst...
:roll:
PostPosted: Wed Jan 11, 2012 12:08 pm
Very nice - my wife and I went to Las Vegas in ´96 and got both - married and pregnat!
But back to topic:
If the valve is such important - why has somebody taken it off? Worst of all the shaft, on wich the flap should be installed, is bend. I've tried to pull it out, but it didn't work. There's a little 'nose' right in the middle off the shaft, that keeps the shaft in the bearings.
What can I do? Is there a posipossibilityorder a new one at chrysler?
Achim
´67 Dodge A 100
PostPosted: Wed Jan 11, 2012 5:56 pm
People remove the heat valve because they do not properly understand its purpose and function.
The shaft cannot be removed without cutting it, and installing the new shaft requires welding. The repair kits are no longer generally available; you have to find new old stock if you want one. It may be easier and less expensive to replace the whole exhaust manifold. New (Chinese-made) ones can be bought for around $120.
PostPosted: Thu Jan 12, 2012 5:52 am
welcome to the board. you'll find a lot of good stuff here.
more off topic but a couple of years ago i was able to return to the Darmstadt region and visited my ancestors home town. They migrated from Germany to SE Ohio in 1847 and came from a little town near Darmstadt called Kleestadt
are you familiar with that place?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 3 guests
