It is currently Sat Oct 10, 2026 10:25 am
PostPosted: Sun Dec 11, 2011 5:16 am
picked up a set of K1 rods for a future build,, did some trial fitting and inspection to see what these were like.
saw that the King rod bearings did not want to seat fully in the cap or the body at the bearing tang
K1 rod the lock slot is .124 wide and .050 deep
stock rod, lock slot is .162 wide and .100 deep
King bearing lock is .155 wide and .100 deep
http://www.flickr.com/photos/13718356@N ... 371245959/
I had seen the posts where on the early K1's the slots were on the wrong side,, this set is OK for that,, but looks like the slots are small,,
for these bearing anyway..
1) do folks normally just open the slot in the rod-cap with a dremel?
2) and since there is no spurt oiling on these,,, is there a front and a rear for installation?
thanks
DT
PostPosted: Sun Dec 11, 2011 5:56 am
are the rods in question for a cast crank? I think I should go measure my set of k1's(cast crank) to see if this is something else to worry about :roll:
PostPosted: Sun Dec 11, 2011 6:32 am
Poser
And you didn't get me a set for Christmas? Some friend you are DT! :lol:
PostPosted: Sun Dec 11, 2011 6:40 am
Some of the rods had this problem, and my shop just fixed it with a little mill notch. I haven't checked my other set yet. I would probably use a hand file. You will need to enlarge the slot, or the bearing will not crush properly.
PostPosted: Sun Dec 11, 2011 8:31 am
yes, these are cast crank rods,,
the bearing shell needs to fully seat, if it gets held out, you will loose clearance for the oil film..
I got these through campbellenterprises,,I'll call them and K1 on Monday,, I'll fix these myself,, but they should not be letting these off the shelf like this.
and what about the rod orientation?
when putting the rods in the engine, does one just put the lock slots on the same side as the OE rods?
WV,, dude, it ain't Christmas yet,,you may have a set coming,, so go ahead and hold your breath! :lol:
PostPosted: Sun Dec 11, 2011 8:59 am
And I remember when Tom was on here bragging that even though their forgings were Chinese the machine work and final inspections were done here. :lol:
PostPosted: Mon Dec 12, 2011 10:46 am
spoke with Susan at K1 about the lock slot size question,, she checked the print and said,,,
you are right,, the width should be .165,, K1 does spec the depth at .050
She said she will follow up with the manufacturing operation to get a correction
and got an e mail and return call from CampbellEnterprises,,
talked with them and they said they would follow up with K1..
PostPosted: Mon Dec 12, 2011 6:40 pm
Poser
Good ta have a quality control parts type engineer in house!
PostPosted: Tue Dec 13, 2011 2:07 pm
yea, they should have found that,, bet there is a buch of them out there like this...
 Post subject: k1 cast crank rods
PostPosted: Sun Dec 18, 2011 3:19 pm
I got a set with wrong size groove, just opened them up with a small cut off saw blade on a dremel, no problem
PostPosted: Sat Jan 14, 2012 4:15 pm
bumping this, any word if these rod issues have been fixed, or a time frame when they will be ?? I will be getting a fat tax return this year, woo hoo having a son and steady check, and want to get this and the wiseco piston setup for my beastly turbo build,
-Mike
I am the Guardian, I hate helos, everything leaks.......
PostPosted: Sun Jan 15, 2012 6:58 am
i checked the set i have yesterday- also the wrong slot for the bearing :x
PostPosted: Sun Jan 15, 2012 7:09 am
Would it be easier to narrow the tang on the bearing?
PostPosted: Sun Jan 15, 2012 7:20 am
I am sure you could, the main thing is the bearing shell needs to fit properly in the rod half round,, or you will loose clearance for the oil film..
PostPosted: Sun Jan 15, 2012 7:34 am
I would also worry about alignment.
Users browsing this forum: Amazon [Bot], Google [Bot] and 25 guests
