It is currently Sun Oct 11, 2026 2:11 pm
Post new topic  Reply to topic  [ 18 posts ]  Go to page Previous 1 2
PostPosted: Fri Jan 13, 2012 7:46 pm
thanks fellas , I'll be going to work on it here soon...
PostPosted: Sat Jan 14, 2012 7:19 pm
Progress!! Took the bolts out of the rocker shaft and got a bottle type brush in there(large tube brush for cleaning tattoo tubes) , got some crusty stuff out. I now have what looks like sufficient flow to the rockers.
Found a leaky vacuum line at the "air cleaner vacuum tube" replaced it, and this has made an improvement(it was stiff and cracky which I think was getting worse as I repeatedly pulled and replace the air intake)
Ted I have been pouring over the "Holley 1920 air bleed/idle transfer slot mods" thread and realized this is an adjustment I have over looked. The 1920 I have has a large idle air bleed with an adjustment screw on the side. This thing was wide open, probably 3 full turns out. I just now readjusted it to one turn out, and the idle mixture to 4.5. I'll have to mess with the idle more when I can check the Rpms.
Improvement in transition from idle to main circuit,
Still some "miss" and or roughness at idle, though it is muuuch better now!!
PostPosted: Sat Jan 14, 2012 8:35 pm
That is good news....!
Users browsing this forum: Amazon [Bot], Google [Bot], Plymouth_Ruster and 25 guests
