It is currently Thu May 14, 2026 2:04 pm
PostPosted: Fri Jan 13, 2012 10:43 am
i'm putting in a pair of bucket seats from a mid 90's mustang. i wanted to reinforce the floor with some sheet metal around the mounting points for the seats. i have some 5x5 squares and was thinking about welding them to the floor.
my question: Is it necessary to weld the 5x5 squares to the floor? also, should i put them on the top side or bottom side of the floor? which would give me the better result?
70 Plymouth Valiant 4dr
PostPosted: Fri Jan 13, 2012 11:44 am
I'd put them on the top.
Scott - waywardgarage.com
Why is the rum always gone? Image
PostPosted: Fri Jan 13, 2012 11:52 am
I think you'd get more strength by putting them on the bottom. Isn't that where the factory put them? But I don't think they need to be as large as 5" square. Look underneath your car and see what's there now (I'm at work and don't have access to my car right now).
PostPosted: Fri Jan 13, 2012 3:29 pm
Put them on the top. You will probably have to trim them to fit around the contours of the floor anyway. :D
PostPosted: Sun Jan 15, 2012 7:32 am
Scott Smith at Harms Automotive sells the ones that go on the bottom.
I will need a set if I ever get back to work on the Duster.
PostPosted: Mon Jan 16, 2012 11:04 am
On early A's, the factory put them on top.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Mon Jan 16, 2012 11:16 am
I'd run em on top, then from underneath use a large fender washer to sandwich the floor for a bit more strength. The fender washer could also be tacked into place.
